302 Issues, Probably self Inflicted... Experts?
Old March 30th 16, 02:49 AM posted to rec.aviation.soaring
Linwood Stevenson
Default 302 Issues, Probably self Inflicted... Experts?
On Tuesday, March 29, 2016 at 9:15:35 PM UTC-4, Tango Eight wrote:
On Tuesday, March 29, 2016 at 8:35:45 PM UTC-4, Linwood Stevenson wrote:
Hi All,
Previous flight last week my 302 abruptly quite recording mid flight, a fact I wasn't aware of until after landing and viewing the downloaded .igc file. Was a good 400k+ flight too, but thats beside the point.... Anyway, checked out the log file and it appeared to be full, so I assumed (first mistake) that the memory wrap around feature didn't wrap around. Fix was to clear the log, which I've occasionally done in the past.
So, today when starting the 302 it wasn't locking on satellites after 15 minutes or so. I was in line for a tow, and if I didn't take the tow, would have lost the tow plane for the day. Off we go, no satellites acquired.. A few minutes after the release, the satellites finally acquired, and all other 302 features appeared normal. After return home, attempted to download the .igc file once again, only to be greeted with a message to the effect that there were no log files to be downloaded, and none were displayed on the screen...
So, question is, should the 302 start a partial log once the satellites are acquired, or will the log pages stay blank, as they did today. Am I looking at a possible 302 failure, or is this simply operator error on my part?
On top of that, the PowerFlarm portable isn't logging any .igc files either. Might be dead in the water for the Perry contest. Issues always happen before a contest or other event it seems....
Thanks in advance for any suggestions or help!
7B
Check for GPS antenna interference (start by running the 302 alone... see if it locks up faster/more reliably without other GPS devices switched on).. If interference suspected, move antennas around. 12" clearance between GPS antennas always works. 6" usually works. Less is a little dicey.
If the problem turns out to be your 302... I have a spare 302 I'd be happy to loan for the contest. Has the GPS date bug fix.
Best,
Evan Ludeman / T8
Thanks Evan,
Mine had the GPS and date fix recently, but its alway has and still is flakey on satellite acquisition. Somedays works in the garage, other days takes 20+ minutes under a clear sky, like today... 302 is old but reliable unit, but maybe its had its day... might look at some of the newer stuff that also records .igc....
Appreciate your kind offer of 302 loan. Got a bit more beating on the 302 tomorrow to see if there is something else to do, then will go from there and let you know... Thanks again!
Steve
7B
Old March 30th 16, 09:32 AM posted to rec.aviation.soaring
Tim Newport-Peace[_2_]
Hi All,
=20
a=
.igc=
Anyway,=
m=
to=
clear the log, which I've occasionally done in the past. =20
=20
1=
wo=
acquired=
al=
down=
eff=
displayed
on the screen...
=20
satellites=
l=
pa=
rt?
=20
ei=
hap=
=20
7B
=20
see=
on)=
between
=20
happ=
y to loan for the contest. Has the GPS date bug fix. =20
=20
=20
Best,
=20
Evan Ludeman / T8
Thanks Evan,
flak=
take=
unit=
a=
302
a=
Steve=20
7B
As I recall, the 302 should record as a barograph, even without GPS lock
once vertical movement has been seen, back-logging for a short while.
Sound like its broke.
Big Q for the Prop Experts? [email protected] Piloting 9 April 4th 08 03:40 AM
GNS 530... Any experts? [email protected] Piloting 7 August 30th 06 04:38 PM
For the electronics experts here mark Home Built 5 July 5th 06 02:26 AM
Any P51 experts out here? Dudley Henriques Naval Aviation 18 February 15th 05 08:27 AM
Are There Any P-47 Experts Out There Too? Schlomo Lipchitz Naval Aviation 10 February 15th 05 03:06 AM
