Wireless external GPS antenna for iPad/mini devices
Old April 15th 16, 05:56 PM posted to rec.aviation.soaring
Default Wireless external GPS antenna for iPad/mini devices
Does anyone have suggestions for the best wireless external GPS antennas for iOS devices, iPad, iPhone, etc.? I'd like to try iGlide running
on my iPad mini.
Thanks,
Steve
Old April 16th 16, 04:54 AM posted to rec.aviation.soaring
Bill T
If your iPad mini does not have the internal GPS, I.e. It's a wifi only model, I have the Air2 in the same configuration.
I use Bad Elf Pro via Bluetooth connection for the GPS input.
I have not tested, but I believe the Nano Data logger will also connect via Bluetooth. Using Bluetooth in the nano decreases battery life by 1/2 according to the manual.
I run ForeFlight on the Air2 with the Bad Elf GPS data for powered flying.
I connect my nano to Oudie for glider.
BillT
Old April 16th 16, 10:21 AM posted to rec.aviation.soaring
Kilo-Bravo
Hi Steve,
I just bought a GPS-Logger for my new iPad-Mini2 at Amazone for 83 EURO:
"GNS Navilock GPS/GLONASS 2000 BT f.iPhone/iPad incl. Logger"
I just checked the logger during a 3,5 hour flight in my Banjo - worked fine!
Best regards from Germany
Klaus
ul-segelflug.de
Old April 16th 16, 05:15 PM posted to rec.aviation.soaring
Hi Bill and Klaus, thank you for the input. The Nano idea may be the solution as this nav setup is for my 1-26 and I've been using the Nano for
Logger and GPS input for my Compaq Aero 1550. The iGlide is such a nice display on the iPad mini. I had forgotten that the Nano has Bluetooth.
Klaus, where are you from in Germany? I flew F-16s at Hahn from '84-'87 and learned to fly gliders at DASC above Traben-Trarbach. Loved it there!
Old April 17th 16, 09:05 AM posted to rec.aviation.soaring
Kilo-Bravo
Hi Bill,
Aviators world is indeed very small.
I live in Ober-Ramstadt, 15km east of Darmstadt and I fly in Bensheim (Bergstrasse/Odenwald).
Last fiofe years, I organized trsnsition-courses for Ultralight-Soaring in Bad Sobernheim, only few km southeast of Hahn.
Just visit my website "ul-segelflug.de" and you will find everything about it.
Klaus
Old April 17th 16, 02:09 PM posted to rec.aviation.soaring
Jonathan St. Cloud
As you probably know the iPad version with cellular data has a GPS chip that works even if yo have not activated the cell data. So you only need GPS data if your iPad is wifi version only.
on my iPad mini.
Thanks,
Steve
iGlide and iPad mini Jonathan St. Cloud Soaring 4 October 15th 15 06:34 PM
iPad mini/iGlide Ross Whittle Soaring 10 July 28th 14 03:46 AM
Using an iPad mini for soaring stuff Eric Greenwell[_4_] Soaring 28 December 30th 13 08:53 PM
iPad Mini Kneeboard? Anthony E Piloting 1 March 29th 13 01:37 PM
Ipad compatible bluetooth GPS which has an external antennasocket and external pwr input? macpacheco Instrument Flight Rules 1 November 12th 11 03:32 PM
