91.205 compass requirement
Old April 20th 16, 12:05 AM posted to rec.aviation.soaring
Default 91.205 compass requirement
On Tuesday, April 19, 2016 at 12:10:43 AM UTC-7, wrote:
How does 91.205 apply to self-launching gliders? Or to touring motor gliders?
They are registered as gliders?
My motor glider is registered as a glider, Jim. But 91.205 does not use the word 'glider' it refers to 'Powered civil aircraft with standard category U.S. airworthiness certificates'. I have a self launcher, so would argue that although my glider is an aircraft, and is powered, the power is incidental to the flight, so its not a 'powered aircraft' as the FAA would define it. See also the FAA definition of a glider at the start of the FARs. I'm just guessing at the FAA's view here. But a touring motor glider might well be considered a 'powered aircraft' by the FAA, I'd guess, since its designed to cruise under power for a significant part of any flight.
Old April 20th 16, 04:40 AM
OregonGliderPilot OregonGliderPilot is offline
Junior Member
First recorded activity by AviationBanter: Sep 2009
Powered civil aircraft is a different category from gliders. All forms of motor gliders are just gliders that can self launch, tour or sustain themselves. 91.205 is not relevant to gliders, but the POH minimum equipment list is what the FAA will look at for standard category gliders with regards to compass fitment.
It could be argued that any system using a magnetic field sensor meets the definition of a magnetic compass with the proviso that it needs to be swung to match the local field disturbance from any metalwork in the vicinity. Maybe not gps systems? What you don't want to see is any reference to a liquid or "whiskey" compass.
Old April 20th 16, 02:50 AM posted to rec.aviation.soaring
Darryl Ramm
Why does this question keep coming up on r.a.s.. A motorglider of any type is a *glider*. There is no mystery here.
Old April 20th 16, 02:59 AM posted to rec.aviation.soaring
Bill T
Is it certificated as Standard or Experimental?
Standard is outlined in 91.205, not experimental.
BillT
Requirement of AW 139 pilot sanjay Rotorcraft 2 August 25th 08 10:06 AM
IFR Alternate Requirement gwengler Instrument Flight Rules 18 May 18th 05 02:26 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
CFI logging requirement [email protected] Owning 9 October 19th 04 07:11 PM
Mode S to become requirement? Bob Chilcoat Owning 6 July 14th 04 11:25 PM
