Flarmnet problems on Flarmview
Old May 2nd 16, 09:51 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Default Flarmnet problems on Flarmview
I did try with and without the conversion process (.fln and .flx) but still not working.
On Monday, May 2, 2016 at 10:45:16 AM UTC-7, Tango Eight wrote:
On Monday, May 2, 2016 at 11:23:22 AM UTC-4, Karl Kunz wrote:
Just installed a Flarm Core with a Flarmview2 display. Installed the Flarmnet file after running it thru the converter required by LXNav and not getting IDs. My partner also installed the same file on his Flarmview1 with the same result. Is anyone else having this same problem?
What did you name the converted file? IIRC it must be flarm.flx. The converter will happily allow you to give the file other names, which won't work.
best,
Evan Ludeman
FlarmView and FlarmNet- will they work together? Matt Herron Jr. Soaring 3 April 11th 15 11:11 PM
New FlarmView Flarm Config Menu? [email protected] Soaring 0 February 27th 14 05:06 PM
LXNAV Flarmview [email protected] Soaring 2 September 29th 13 01:47 AM
PF Portable and Flarmnet Andy[_1_] Soaring 0 October 5th 12 02:55 PM
FlarmNet Brad[_2_] Soaring 6 August 26th 12 06:35 PM
