FWIW
The current system is so easy and quick - I doubt the effort to separate the files would/should/could ever happen. To be sure - I just checked - it took less than 5 seconds to down load the entire Sports Class nationals files - 40 gliders x 4 days - that's allot of tracks for little investment. if it takes longer than you are doing something wrong - you just right click on the "Flight Logs" in the results and save the target to your desktop - you get them all ![]() WH |
I suppose that if I'd suggested hamburgers for lunch, there'd be RAS posts here expressing what a waste it would be to suggest someone cook the meat when it is just as nutritious eaten raw.
On Tuesday, August 16, 2016 at 5:00:26 PM UTC-5, Steve Koerner wrote:
I suppose that if I'd suggested hamburgers for lunch, there'd be RAS posts here expressing what a waste it would be to suggest someone cook the meat when it is just as nutritious eaten raw. Or someone will ask why you are eating beef. :-) Yes, WH, you can get all the files just that quickly. Now go and just as quickly try and get Tony, Tom, and Mark's files from day 3. Takes more than a bit longer, doesn't it? That is what Steve has asked for. Rather than just listing the file name on the scoresheet, make that file name on the scoresheet a link to the file, just like it is on soaringspot. He has politely suggested something for the "improvements" list. Agree, Hank. It is doing what it had been asked to do. And now, a qualified person can have a look and see what level of effort would be involved in taking it to this next level. It may be a little and it may be a lot. Never know if you don't ask. I would like to see it, as I do tend to go look at my flights compared to others above me on the scoresheet. And even after making my "de-coder sheet", I find that pilots don't always turn in files from the same logger each day, so when you can't find the file you are looking for, you have to go digging again. The other Steve |
On Tuesday, August 16, 2016 at 1:31:06 PM UTC-7, wrote:
FWIW The current system is so easy and quick - I doubt the effort to separate the files would/should/could ever happen. To be sure - I just checked - it took less than 5 seconds to down load the entire Sports Class nationals files - 40 gliders x 4 days - that's allot of tracks for little investment. if it takes longer than you are doing something wrong - you just right click on the "Flight Logs" in the results and save the target to your desktop - you get them all ![]() WH Say I'm flying a 3 class contest consisting of 65 gliders and I'd like to retrieve the top 10 scores in my class. It takes more than 5 seconds.... |
Just wishing! | birdog[_2_] | Piloting | 11 | December 24th 10 06:18 AM |
Will Cambridge GPSNAV score in 2k6 OLC? | Stewart Kissel | Soaring | 1 | October 30th 05 05:52 PM |
OLC score calculation? | ttaylor at cc.usu.edu | Soaring | 4 | August 24th 05 01:50 AM |
Wishing for an early spring. | George William Peter Reinhart | Soaring | 0 | October 3rd 03 07:59 PM |
Day 2 New Castle Score Sheet | Guy Byars | Soaring | 3 | September 25th 03 02:39 AM |
