On Friday, October 21, 2016 at 11:26:02 AM UTC+3, Tango Whisky wrote:
Assuming they simply started this construction technique at some point in time, and didn't start-stop-start it, you don't have to open EVERY wing. If the wing of SN #N is opened for any reason and found to be ok, then you can assume that all lower SNs are ok too. Conversely, if it's not ok, then you can assume that all higher SNs are bad too. No, you can't. If for some reason (end of shift, lunch break,...)there was more time between the epoxy filling and the lay-up of the spar cap, there wouldn't be any ondulations. The only valid assumption is that all S/N's are affected. Even given what you say, if you find a bad one then all later ones are at least suspect. |
Absolutely. |
At 13:13 21 October 2016, Bruce Hoult wrote:
On Friday, October 21, 2016 at 11:26:02 AM UTC+3, Tango Whisky wrote: Assuming they simply started this construction technique at some point in time, and didn't start-stop-start it, you don't have to open EVERY wing. If the wing of SN #N is opened for any reason and found to be ok, then you can assume that all lower SNs are ok too. Conversely, if it's not ok, then you can assume that all higher SNs are bad too. No, you can't. If for some reason (end of shift, lunch break,...)there was more time between the epoxy filling and the lay-up of the spar cap, there wouldn't be any ondulations. The only valid assumption is that all S/N's are affected. Even given what you say, if you find a bad one then all later ones are at least suspect. I would agree with the manufacturer's findings saying that ALL DG-300's are suspect, regardless of s/n. That is why the TN applies to all aircraft. I know of three DG300 that have had the wings opened up (a costly affair). Two of them were found to have issues that needed rectification. The OK one had a higher s/n than the ones which needed work. |
dg300 elan questions | Christian de Vet | Soaring | 0 | May 6th 11 03:04 PM |
Got a problem with my wooden spar. | Lou | Home Built | 3 | June 4th 08 01:45 PM |
Would you by DG300 ? | [email protected] | Soaring | 9 | October 8th 07 09:41 PM |
DG300 horizontal stab. bolt saftey wire | [email protected] | Soaring | 2 | June 26th 07 03:35 PM |
DG300 Tail weight | John Schaffer | Soaring | 3 | September 12th 06 09:36 AM |
