Sailplane Power Supply
Old January 27th 17, 08:38 PM posted to rec.aviation.soaring
Default Sailplane Power Supply
Nice writeup and diagrams.
What I, and others, do is similar to one of yours.
Behind the panel, there is a single "common buss" for "+" and "-" that feeds all devices. Feeding that are 2 batteries, each with their own simple on/off master switch.
You then have 3 modes of operation:
-feed everything from battery 1
-feed everything from battery 2
-feed everything from both batteries at once. There is the previously stated issue regarding batteries at different states of charge, different ages, etc.
Plenty of our electronics can display battery voltage or add in a simple panel voltmeter to watch the "device side of the buss" to monitor battery/system voltage.
When voltage gets low, turn on the second battery and THEN turn off the first battery so everything remains powered.
I like to use screw type terminal strips to make it easier to add/remove devices.
These are nice since they've harder to short out.....
http://www.mouser.com/ProductDetail/...zIEaApPW8P8HAQ
These can be used with ring or fork terminals.....
http://www.mouser.com/ProductDetail/...NsEaAm_D8P8HAQ
Old January 28th 17, 03:58 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
I've concluded that this is the best solution, with one modification - each battery is connected through and ideal diode so there is no cross-charging.. Unlike Schottky diodes, which have on the order of a 0.5 volt drop at typical glider panel currents, ideal diodes have only a 0.03 volt drop up to about 10 amps.
9B
On Friday, January 27, 2017 at 12:38:59 PM UTC-8, Charlie M. (UH & 002 owner/pilot) wrote:
Old January 28th 17, 02:34 PM posted to rec.aviation.soaring
On Friday, January 27, 2017 at 9:58:39 PM UTC-6, Andy Blackburn wrote:
I've concluded that this is the best solution, with one modification - each battery is connected through and ideal diode so there is no cross-charging. Unlike Schottky diodes, which have on the order of a 0.5 volt drop at typical glider panel currents, ideal diodes have only a 0.03 volt drop up to about 10 amps.
9B
My (new to me) ClearNav has an excellent option for monitoring the battery in use. The voltage is displayed as soon as it drops below a level that can be set by the pilot. Now just switch to the secondary power source.
Herb
Old January 29th 17, 06:19 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Diodes - @9B - Yep. Watch out for those lost volts. Regular 1N4xxx series diodes commonly used are even worse than Schottky! And you can also loose volts by using too small of wire (14ga for the main run), or too small of breakers. Breakers? Yes, breakers. Stick with 5A breakers or larger as even 4A breakers loose 0.3V and 1A breakers are awful loosing 1.1V (Klixon spec max voltage drop)!! Who knew?
Old January 29th 17, 07:22 PM posted to rec.aviation.soaring
Steve Koerner
On Sunday, January 29, 2017 at 11:19:25 AM UTC-7, OHM Ω http://aviation.derosaweb.net wrote:
Most new setups use Lithium batteries these days. Lithiums do a very good job of holding voltage until the bitter end. That makes the forward drop from a Schottky combiner pretty insignificant. Agree about the low amp breakers though.
Old January 29th 17, 07:51 PM posted to rec.aviation.soaring
John Carlyle
I prefer to keep things simple, similar to Charlie M above. In my ship each battery has a 10 amp fuse and an on-off toggle switch. These toggle switches feed a single master on-off switch, which then feeds individual blade fuses for each instrument. Each instrument also has an on-off switch. Reliable, easy to control, and low voltage loss.
-John, Q3
Old January 29th 17, 06:11 PM posted to rec.aviation.soaring
Charlie - Two comments on your comments.
1) These are nice since they've harder to short out.....
OHM - When I use these I crimp on "pin" terminals rather than sticking the bare wire into each hole.
2) These can be used with ring or fork terminals.....
OHM - Use only ring lugs. After months of flying vibrations the screw holding the "Spade" (fork) terminals will back out slightly and the terminal will fall out.
Power Supply in 98 C182S [email protected] Piloting 1 April 23rd 07 09:55 AM
Power Supply in 98 C182S [email protected] Owning 1 April 23rd 07 09:55 AM
Power Supply in 98 C182S Dan[_1_] Piloting 12 April 16th 07 06:40 PM
Power Supply in 98 C182S Dan[_1_] Owning 12 April 16th 07 06:40 PM
WANTING GYRO POWER SUPPLY ???? Tony Home Built 5 March 7th 06 07:17 PM
