I believe everyone will agree to use a fuse close to/at each battery to give protection in case a wire is shorted somewhere along it's length, etc.
The OP (in his link) mentions this, but also indicated them being eliminated in his drawings to keep it simple. As to a pin, ring terminal, fork terminal, soldering a boot at the open end can help with connectivity over time. Just don't wick solder up past the other end of the crimp to preclude making a stress point. Wiring should also be fine stranded so it's flexible, solid wire can fatigue fail over time due to work hardening of copper with even minor bending. |
Power Supply in 98 C182S | [email protected] | Piloting | 1 | April 23rd 07 09:55 AM |
Power Supply in 98 C182S | [email protected] | Owning | 1 | April 23rd 07 09:55 AM |
Power Supply in 98 C182S | Dan[_1_] | Piloting | 12 | April 16th 07 06:40 PM |
Power Supply in 98 C182S | Dan[_1_] | Owning | 12 | April 16th 07 06:40 PM |
WANTING GYRO POWER SUPPLY ???? | Tony | Home Built | 5 | March 7th 06 07:17 PM |
