302 vs clearnav vario with XCSoar
Old March 11th 17, 02:49 AM posted to rec.aviation.soaring
Dan Marotta
Default 302 vs clearnav vario with XCSoar
The Streak is used by my wive / #1 copilot. My ClearNav II continuously
displays wind direction/speed and headwind component (+,-).
Dan
On 3/10/2017 10:42 AM, Ramy wrote:
Thanks Dan. You may want to continue using this info box. Make sure to select "Head wind component (simplified)". Not sure why they choose to call it this way but the other one is calculated while the simplified is using the true airspeed data from XCSoar to provide accurate and instantaneous real time HW/TW. I found I am checking it more often than the calculated vector wind.
Ramy
Dan, 5J
Old March 12th 17, 10:39 PM posted to rec.aviation.soaring
6PK
I just finally got to fly with my newly installed ClearNav digital vario, connected to a Kobo running Tophat.
Other than some minor issues all seems to work as advertised.
(The Kobo rocks)
6PK
ClearNav Vario Question Dan Marotta Soaring 2 April 3rd 16 02:42 AM
ClearNav Vario and XCSoar Dan Marotta Soaring 9 January 2nd 15 11:33 PM
WTB Clearnav Xcountry Vario Go Soaring Soaring 0 January 26th 14 01:29 PM
More Vario Questions - ClearNav SteveB_Z5 Soaring 4 June 12th 12 02:24 AM
ClearNav Vario Paul Remde Soaring 5 January 8th 11 11:34 PM
