![]() Quote:
If interested in seeing what I come up with, when I get it, email me direct at alstonbk at gmail dot com. Safe soaring! Brad. |
I'm about 95% finished coding a nice iPhone based Powerflarm configurator.
My Flarmview had been giving me a message that said their was an issue with the config file and I finally tracked down the not so obvious detail on Sunday. I need to do the storyboard for the iphone 5 screen size and then submit to Apple, so it's pretty close to being finished. I had hoped to utilize the iXpand USB stick from SanDisk to go direct from iphone to PowerFlarm, but I'm not sure the PowerFlarm will play nice with the SanDisk USB. I need to test that again. Plan B is iphone app to email to clubhouse computer to USB to PowerFlarm. Mark |
On Wednesday, April 12, 2017 at 4:16:58 AM UTC-7, wrote:
I had hoped to utilize the iXpand USB stick from SanDisk to go direct from iphone to PowerFlarm, but I'm not sure the PowerFlarm will play nice with the SanDisk USB. I need to test that again. I've had good luck using the HooToo USB drive to transfer files from the PowerFLARM to iPhone. And I would be very interested in the config utility as well. -Tom |
What's an "iPhone"? :-)
On Wednesday, April 12, 2017 at 7:16:58 AM UTC-4, wrote: I'm about 95% finished coding a nice iPhone based Powerflarm configurator. My Flarmview had been giving me a message that said their was an issue with the config file and I finally tracked down the not so obvious detail on Sunday. I need to do the storyboard for the iphone 5 screen size and then submit to Apple, so it's pretty close to being finished. I had hoped to utilize the iXpand USB stick from SanDisk to go direct from iphone to PowerFlarm, but I'm not sure the PowerFlarm will play nice with the SanDisk USB. I need to test that again. Plan B is iphone app to email to clubhouse computer to USB to PowerFlarm. Mark |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 0 | April 8th 16 08:57 PM |
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm | [email protected] | Soaring | 28 | March 12th 16 04:31 AM |
Flarmview and Powerflarm Core Config File? | Papa3[_2_] | Soaring | 4 | May 18th 15 10:51 PM |
Flarm Update - change to config file required? | Papa3[_2_] | Soaring | 6 | April 28th 15 11:01 AM |
New FlarmView Flarm Config Menu? | [email protected] | Soaring | 0 | February 27th 14 05:06 PM |
