![]() Quote:
Safe soaring! Brad. Parameter: NMEAOUT1 Setting: 73 NMEA Ver. 7 - FLARM (inc. PGRMZ) only Parameter: BAUD1 Setting: 5 57.6 kBaud Parameter: NMEAOUT2 Setting: 73 NMEA Ver. 7 - FLARM (inc. PGRMZ) only Parameter: BAUD2 Setting: 5 57.6 kBaud Parameter: RANGE Setting: 65535 (Unlimited) Parameter: VRANGE Setting: 2000 m (6562 ft) Parameter: ADSBRANGE Setting: 6000 m (19685 ft) Parameter: ADSBVRANGE Setting: 1000 m (3281 ft) Parameter: PCASRANGE Setting: 3000 m (9843 ft) Parameter: PCASVRANGE Setting: 800 m (2625 ft) Parameter: MODEC Setting: 1 (On) Parameter: OWNMODEC Setting: 0 (Off) Parameter: PCASCALIBRATION Setting: 30 Parameter: XPDR Setting: 2 (Mode-S) Parameter: MODESALT Setting: 1 (On) Parameter: PCASBEEP Setting: 0 (Off) Parameter: PCASPFLAU1 Setting: 1 Parameter: PCASPFLAU2 Setting: 1 Parameter: AUDIOOUT Setting: 0 (Off) Parameter: AUDIOVOLUME Setting: 100 Parameter: ID Setting: YOUR 6-DIG Parameter: ACFT Glider/Motor Glider Setting: 1 Parameter: PILOT Setting: YOUR NAME HERE Parameter: LOGINT Setting: 4 s Parameter: GLIDERID Setting: YOUR REGISTRATION Parameter: GLIDERTYPE Setting: YOUR GLIDER Parameter: COMPCLASS Setting: YOUR CLASS Parameter: COMPID Setting: YOUR ID Parameter: PRIV Setting: 0 (Off) Parameter: NOTRACK Setting: 0 (Off) |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 0 | April 8th 16 08:57 PM |
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm | [email protected] | Soaring | 28 | March 12th 16 04:31 AM |
Flarmview and Powerflarm Core Config File? | Papa3[_2_] | Soaring | 4 | May 18th 15 10:51 PM |
Flarm Update - change to config file required? | Papa3[_2_] | Soaring | 6 | April 28th 15 11:01 AM |
New FlarmView Flarm Config Menu? | [email protected] | Soaring | 0 | February 27th 14 05:06 PM |
