Tow Plane Upsets......
Old April 24th 17, 04:21 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Quote:
Originally Posted by Peter Whitehead View Post
A manual release system will never be suitable to stop the rapid pitch up caused in this situation. It happens too fast for a manual (actually a sensory-brain-muscle-manual) system, however good the manual system on the tug.
Glider CofG winch hooks are not really suitable for aero-towing, are they? Some of these gliders can't be controlled in pitch once the kiting starts. I have seen people leave their shoulder starts loose on areotowing, and that means the pilot can slide backwards - with hand held on the stick, so that moves too - on pitch-up. (Always use tight shoulder straps on launching, please).
I have lost two acquaintances, both gliding "greats" in such tug upsets. I would say banning the use of aero-towing using a CofG winch hook would be the safest bet to save lives, until an automatic system is available.I suspect this is something EASA and the FAA would sort very quickly ( the banning bit, not the automatic system). Sensors to measure pitch, rate rate of the tug, and also tug/rope angle and angular rate,suitably processed and actioned automatically could allow immediate release BEFORE the critical situation is reached - if we feel that we must continue to launch by aero-tow using CofG hooks.
A rule of nose hooks or "compromise" hooks only, meanwhile, would probably reduce the risk towards zero.
Peter,
Both of these incidents were with nose releases not CG hooks. I've never really had a problem with a CG glider but I guess it could happen. Both of these incidents were due to extreme carlessness and or inexperience on the part of the glider pilot. My concern is with the inability to release at the critical moment. It will be my purpose to communicate this condition as broadly and relentlessly as possible. No commercial operation or club should be towing with a Schweizer hook or a release not immediately available to the tow pilot.
Walt
Slow Tows and Upsets 7C Soaring 0 March 4th 14 11:41 PM
F-35: Second test plane powers up, but first plane stays grounded Mike[_7_] Naval Aviation 1 October 29th 07 09:40 PM
the plane! the plane! protect it without photons. Spike Home Built 0 December 17th 05 03:28 AM
Plane down - NASCAR team plane crashes... Chuck Piloting 10 October 28th 04 12:38 AM
Kit plane boom with Sport Plane rules Dave Home Built 1 February 4th 04 02:37 PM
