In article , hobo
wrote: The corsair used a 3-blade prop. Why didn't they use a smaller 4-blade prop if ground clearance was such an issue? They wanted to keep the main landing gear as short as possible, to simplify structural loads. The Hellcat had a relatively long main gear leg. -- |
![]() "B2431" wrote in message ... Corsair had a 4 bladed prop. It also had a 3 bladed prop. It all depends on the specific model. |
The F4U had a three-blade prop from the XF4U-1. The F4U-4 introduced the
four-blade prop on production Corsairs. (The XF4U-3 had a four-blade prop, but didn't go into production, and the prototypes were returned to their F4U-1 initial state.) I have a formerly classified file of a Vought tech-reps final tour report from 1943. The guy traveled everywhere in the South West Pacific theater, checking on the servicability and operational needs of all US units that used Corsairs at that point in the war. He hit every island that supported Corsair operations, recording every nit pick and shortage among each unit, at times under direct enemy attack. Planes crashed in front of him, he occasionally landed at forward airstrips in the middle of battles and airraids. The only serial problem that the report contains is a repeated cry for tires - since the F6F-3, F4U-1, and TBFs all used the same 32x8 tire, they were in critically short supply. Other problem areas include the cartridge starters and nagging issues with the voltage regulators. The report has comments about every aspect of Corsair operations - surprising to me is that nearly every unit he visited requested a modification for a locked-wing Corsair, with the wing fold mechanism removed for weight saving and increased roll rate. As to props - this is old Jack's only comments: TOUR OF INSPECTION OF THE SOUTH AND CENTRAL PACIFIC AREAS COVERING F4U-1 OPERATIONS, MAINTENANCE, AND SPARES. 30 DEC 1943 LT JOHN J. HOSPERS, USNR Page 32 Material and Equipment 56. All Squadrons have been informed that the F6F-3 propellor is interchangeable with the F4U-1 and that this paddle blade design will improve the performance of the F4U-1. v/r Gordon ====(A+C==== USN SAR Its always better to lose -an- engine, not -the- engine. |
Greg Hennessy writes: On 03 Jul 2004 04:42:25 GMT, nt (Krztalizer) wrote: 56. All Squadrons have been informed that the F6F-3 propellor is interchangeable with the F4U-1 and that this paddle blade design will improve the performance of the F4U-1. Improved by how much I wonder ? I _thought_ I'd posted to this thread yesterday, with a few fidbits on propellers, but the record shows that it didn't make it, for some reason. Anyway - The amount of power that a propeller can absorb (and turn into thrust) is goverened more htna anything else by the total blade area, and its Activity Factor (Essentially its Solidity - the ratio of the area of the ptopeller blades to the total area of the propeller disk.) The higher the solidity, the more power you can absorb. The Efficiency of the propeller, (The amount of Shaft Horsepower that it turns into Thrust) is driven by the Advance Ratio (A product of the propeller's rotational speed vs. the airplane's forward speed), and the blade angle. With a Constant Speed propeller, the blade angle factor is removed, within the limits of the propeller's pitch stops, because the propeller governor will always select the most efficient blade angle to absorb the shaft horsepower. The propeller's pitch range is such that, for any power level normally encountered in flight, the propeller blades are not on the stops, and we can safely ignore it for the purposes of this post, and only consider Advance Ratio. Efficiency drops off at both low and high Advance Ratios, so you can't just shoot for the highest one you can reach. (And, in the WW 2 fighter case, with geared propeller drives, you start to run into efficiency losses at high speed as the propeller blades start going transonic. Other airplanes can get the propeller tips transonic at lower airspeeds. One of the big reasons for a T-6/SNJ's irritating snarl is that, with its ungeared R1340, the prop tips are transonic.) Also, there are purely mechanical considerations - the propeller had to be able to stay together while its working. Propeller blades are thin, but they aren't light, and the forces both along their length (ccentrifugal), and across the propeller disk (Thrust) are high. All the force is concentrated at the blade root at the hub, so not only are there high forces, but they've got long lever arms to work with. You can add blade area in 3 ways - you can increase the propeller diameter, you can increase the area per prop blade, or you can increase the number of prop blades. There are tradeoffs for all three options. Increasing the diameter of the propeller works well aerodynamically at most Advance Ratios, but the tip speeds are high. since most of the thrust of a propeller is generated at the tips, it also puts huge loads on the propeller blade & hub. (And it has to fit on the airplane). Increasing the blade area of each propeller blade ("Paddle Blades") will increase the efficiency at low Advance Ratios, giving better takeoff and climb performance, but at a cost in high Advance Ratio performance, and with added problems with structural strength. It also allows the diamter to be more carefully controlled, with some benefits at high speed. Increasing the number of propeller blades also allows the diameter to be controlled, and doesn't requires as much structural strength per blade as the other two options. It does decrease overall efficiency. (A good rule of thumb is 2-3% per blade) This is due to interference effects of a propeller blade tip running into the vortices of the blade ahead of it. So, in general, the order of merit of the three options is this: 1) Increase the propeller diameter, if practicable. 2) Increase teh propeller blade area without increasing the diameter (Paddle blade) 3) Increase the number of propeller blades. As to the Hellcat propeller being fitted to the Corsair - it was certainly done - for example, the tests performed by the USN of a P-51B vs 2 hotted up Corsairs used Hellcat propellers for both aircraft. (The preort can be found online at: http://www.geocities.com/slakergmb/id95.htm As to how much it would affect performance - The Hellcat propeller would mose likely by about 2% more efficient at the F4U's climb speed, and about the same efficency at maximum speed. At climb speed, the 2% greater efficency would give 40 more Thrust Horsepower at Sea Level (2000 SHP), and about 34 more Thrust HP at high altitudes. (This is because the Corsair's geared supercharger delivered less Shaft Horepower at high altitudes, since more power was diverted to the supercharger). At teh Corsair's best climb speed of 135 Kts at Sea Level, that's 95# more excess thrust. it doesn't sound like much, but since it's all excess, it gives about 108 ft/min more climb. At 22,000', the excess thrust would be about 58#, giving a improved rate of climb of 95 ft/minute. It doesn't seem like much, but it makes a difference. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Very interesting! The only part I question is:
"Peter Stickney" wrote... Increasing the diameter of the propeller works well aerodynamically at most Advance Ratios, but the tip speeds are high. since most of the thrust of a propeller is generated at the tips, it also puts huge loads on the propeller blade & hub. How can "most of the thrust" be generated at the tips -- given the combination of shorter chord, lower AOA, and [vortex] airflow around the tips -- compared with the midspan of the blade? |
All I Wanted For Christmas Were Inverted Spins | [email protected] | Aerobatics | 3 | December 29th 04 07:40 PM |
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") | Roberto Waltman | Home Built | 2 | October 29th 04 04:21 PM |
inverted spin recovery explanation | Alan Wood | Aerobatics | 18 | August 19th 04 03:32 PM |
Double covering fabric covered wings | [email protected] | Home Built | 9 | May 9th 04 08:39 PM |
Crooked or Wavy Trailing Edges of Wings and Control Surfaces | Larry Smith | Home Built | 3 | October 24th 03 02:31 AM |
