Greg Hennessy writes: On 03 Jul 2004 04:42:25 GMT, nt (Krztalizer) wrote: 56. All Squadrons have been informed that the F6F-3 propellor is interchangeable with the F4U-1 and that this paddle blade design will improve the performance of the F4U-1. Improved by how much I wonder ? I _thought_ I'd posted to this thread yesterday, with a few fidbits on propellers, but the record shows that it didn't make it, for some reason. Anyway - The amount of power that a propeller can absorb (and turn into thrust) is goverened more htna anything else by the total blade area, and its Activity Factor (Essentially its Solidity - the ratio of the area of the ptopeller blades to the total area of the propeller disk.) The higher the solidity, the more power you can absorb. The Efficiency of the propeller, (The amount of Shaft Horsepower that it turns into Thrust) is driven by the Advance Ratio (A product of the propeller's rotational speed vs. the airplane's forward speed), and the blade angle. With a Constant Speed propeller, the blade angle factor is removed, within the limits of the propeller's pitch stops, because the propeller governor will always select the most efficient blade angle to absorb the shaft horsepower. The propeller's pitch range is such that, for any power level normally encountered in flight, the propeller blades are not on the stops, and we can safely ignore it for the purposes of this post, and only consider Advance Ratio. Efficiency drops off at both low and high Advance Ratios, so you can't just shoot for the highest one you can reach. (And, in the WW 2 fighter case, with geared propeller drives, you start to run into efficiency losses at high speed as the propeller blades start going transonic. Other airplanes can get the propeller tips transonic at lower airspeeds. One of the big reasons for a T-6/SNJ's irritating snarl is that, with its ungeared R1340, the prop tips are transonic.) Also, there are purely mechanical considerations - the propeller had to be able to stay together while its working. Propeller blades are thin, but they aren't light, and the forces both along their length (ccentrifugal), and across the propeller disk (Thrust) are high. All the force is concentrated at the blade root at the hub, so not only are there high forces, but they've got long lever arms to work with. You can add blade area in 3 ways - you can increase the propeller diameter, you can increase the area per prop blade, or you can increase the number of prop blades. There are tradeoffs for all three options. Increasing the diameter of the propeller works well aerodynamically at most Advance Ratios, but the tip speeds are high. since most of the thrust of a propeller is generated at the tips, it also puts huge loads on the propeller blade & hub. (And it has to fit on the airplane). Increasing the blade area of each propeller blade ("Paddle Blades") will increase the efficiency at low Advance Ratios, giving better takeoff and climb performance, but at a cost in high Advance Ratio performance, and with added problems with structural strength. It also allows the diamter to be more carefully controlled, with some benefits at high speed. Increasing the number of propeller blades also allows the diameter to be controlled, and doesn't requires as much structural strength per blade as the other two options. It does decrease overall efficiency. (A good rule of thumb is 2-3% per blade) This is due to interference effects of a propeller blade tip running into the vortices of the blade ahead of it. So, in general, the order of merit of the three options is this: 1) Increase the propeller diameter, if practicable. 2) Increase teh propeller blade area without increasing the diameter (Paddle blade) 3) Increase the number of propeller blades. As to the Hellcat propeller being fitted to the Corsair - it was certainly done - for example, the tests performed by the USN of a P-51B vs 2 hotted up Corsairs used Hellcat propellers for both aircraft. (The preort can be found online at: http://www.geocities.com/slakergmb/id95.htm As to how much it would affect performance - The Hellcat propeller would mose likely by about 2% more efficient at the F4U's climb speed, and about the same efficency at maximum speed. At climb speed, the 2% greater efficency would give 40 more Thrust Horsepower at Sea Level (2000 SHP), and about 34 more Thrust HP at high altitudes. (This is because the Corsair's geared supercharger delivered less Shaft Horepower at high altitudes, since more power was diverted to the supercharger). At teh Corsair's best climb speed of 135 Kts at Sea Level, that's 95# more excess thrust. it doesn't sound like much, but since it's all excess, it gives about 108 ft/min more climb. At 22,000', the excess thrust would be about 58#, giving a improved rate of climb of 95 ft/minute. It doesn't seem like much, but it makes a difference. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Very interesting! The only part I question is:
"Peter Stickney" wrote... Increasing the diameter of the propeller works well aerodynamically at most Advance Ratios, but the tip speeds are high. since most of the thrust of a propeller is generated at the tips, it also puts huge loads on the propeller blade & hub. How can "most of the thrust" be generated at the tips -- given the combination of shorter chord, lower AOA, and [vortex] airflow around the tips -- compared with the midspan of the blade? |
In article PyBFc.18031$%_6.5403@attbi_s01,
"John R Weiss" writes: Very interesting! The only part I question is: "Peter Stickney" wrote... Increasing the diameter of the propeller works well aerodynamically at most Advance Ratios, but the tip speeds are high. since most of the thrust of a propeller is generated at the tips, it also puts huge loads on the propeller blade & hub. How can "most of the thrust" be generated at the tips -- given the combination of shorter chord, lower AOA, and [vortex] airflow around the tips -- compared with the midspan of the blade? Ah, you caught me oversimplifying/underexplaining. Thanks. Because the airspeed of the propeller is much higher at the tips, most of the thrust produced by the propeller is higher there. A simple rectangular prop with a constant chord would, all other things being equal, be developing a tremendouds amount of force at the tips, and hardly any near the hub. This sets up a severe structural problem - a simple propeller shape will have a tremendous bending moment both at the point where the blade joins the hub, and along the length of the blade. (As an aside, you also don't want the propeller blades to be too heavy - a WW 2 fighter propeller blade typically weighed about 100#/45 Kilos). Building strong, lightweight blades that could take these forces and not have, say, problems with resonance, was a difficult and involved process, fraught with danger - It wasn't unusual for a disintegrating propeller to destroy the test cells at Hamilton Standard and Wright Pat, let alone be something that could be trusted in the air - so propeller shapes, before WW 2, were tweaked to provide a fairly constant (at some particular design point wrt prop pitch and airspeed) distribution of forces. This included reducing the area at the tips (Which also decreased the strucural issues), changing the propeller pitch across the propeller blade's length, to keep the lift coefficient the same, and making the shank of the blade completely round. (For greater strength, and for making the pitch-change mechanisms easier to design & build.) using a progressive pitch ditribution (propeller twist) allows for more thrust at low speeds. A typical early WW 2 propeller, with a relatvely narrow propeller blade chord and a fiarly pointed tip produced its maximum thrust in a region between 80 and 90% or the propeller radius. (Ref: NACA Report No. 712, "Propeller Analysis From Experimental Data", Stickles & Crigler, 1940.) As structural techniqes improved during the war, it became possible to make wider chord propeller tips, moving the point of maximum thrust further out along the blade radius. It still doesn't peak at the tips, though, because of the tip vortices. It's still a serious load on the propeller shank. Compare, for example, the early and later CUrtiss Electric propellers used on P-47s - the early propeller blades are "toothpicks", while the later "paddle" blades are nearly rectangular, with the same maximum chord, but held for a much longer section of the blade radius. Or the propeller of a P-40 or P-51A to that of a P-51B. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
All I Wanted For Christmas Were Inverted Spins | [email protected] | Aerobatics | 3 | December 29th 04 07:40 PM |
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") | Roberto Waltman | Home Built | 2 | October 29th 04 04:21 PM |
inverted spin recovery explanation | Alan Wood | Aerobatics | 18 | August 19th 04 03:32 PM |
Double covering fabric covered wings | [email protected] | Home Built | 9 | May 9th 04 08:39 PM |
Crooked or Wavy Trailing Edges of Wings and Control Surfaces | Larry Smith | Home Built | 3 | October 24th 03 02:31 AM |
