In article PyBFc.18031$%_6.5403@attbi_s01,
"John R Weiss" writes: Very interesting! The only part I question is: "Peter Stickney" wrote... Increasing the diameter of the propeller works well aerodynamically at most Advance Ratios, but the tip speeds are high. since most of the thrust of a propeller is generated at the tips, it also puts huge loads on the propeller blade & hub. How can "most of the thrust" be generated at the tips -- given the combination of shorter chord, lower AOA, and [vortex] airflow around the tips -- compared with the midspan of the blade? Ah, you caught me oversimplifying/underexplaining. Thanks. Because the airspeed of the propeller is much higher at the tips, most of the thrust produced by the propeller is higher there. A simple rectangular prop with a constant chord would, all other things being equal, be developing a tremendouds amount of force at the tips, and hardly any near the hub. This sets up a severe structural problem - a simple propeller shape will have a tremendous bending moment both at the point where the blade joins the hub, and along the length of the blade. (As an aside, you also don't want the propeller blades to be too heavy - a WW 2 fighter propeller blade typically weighed about 100#/45 Kilos). Building strong, lightweight blades that could take these forces and not have, say, problems with resonance, was a difficult and involved process, fraught with danger - It wasn't unusual for a disintegrating propeller to destroy the test cells at Hamilton Standard and Wright Pat, let alone be something that could be trusted in the air - so propeller shapes, before WW 2, were tweaked to provide a fairly constant (at some particular design point wrt prop pitch and airspeed) distribution of forces. This included reducing the area at the tips (Which also decreased the strucural issues), changing the propeller pitch across the propeller blade's length, to keep the lift coefficient the same, and making the shank of the blade completely round. (For greater strength, and for making the pitch-change mechanisms easier to design & build.) using a progressive pitch ditribution (propeller twist) allows for more thrust at low speeds. A typical early WW 2 propeller, with a relatvely narrow propeller blade chord and a fiarly pointed tip produced its maximum thrust in a region between 80 and 90% or the propeller radius. (Ref: NACA Report No. 712, "Propeller Analysis From Experimental Data", Stickles & Crigler, 1940.) As structural techniqes improved during the war, it became possible to make wider chord propeller tips, moving the point of maximum thrust further out along the blade radius. It still doesn't peak at the tips, though, because of the tip vortices. It's still a serious load on the propeller shank. Compare, for example, the early and later CUrtiss Electric propellers used on P-47s - the early propeller blades are "toothpicks", while the later "paddle" blades are nearly rectangular, with the same maximum chord, but held for a much longer section of the blade radius. Or the propeller of a P-40 or P-51A to that of a P-51B. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
All I Wanted For Christmas Were Inverted Spins | [email protected] | Aerobatics | 3 | December 29th 04 07:40 PM |
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") | Roberto Waltman | Home Built | 2 | October 29th 04 04:21 PM |
inverted spin recovery explanation | Alan Wood | Aerobatics | 18 | August 19th 04 03:32 PM |
Double covering fabric covered wings | [email protected] | Home Built | 9 | May 9th 04 08:39 PM |
Crooked or Wavy Trailing Edges of Wings and Control Surfaces | Larry Smith | Home Built | 3 | October 24th 03 02:31 AM |
