On 6/06/2017 13:04, Jim wrote:
I have been trying to apply the latest Flarm firmware update to the Flarm in our ASG-32Mi with an LX9000 installed. I have tried many times and every time the result is a "Synchronization Failed" message. I have looked for an explanation of this error message in the Flarm manuals, on the Flarm.com website, on the web in general, on rec.aviation.soaring and have found nothing. Does anyone know what is going on with my update attempts? You can't update the flarm in a 9000 unless you've installed all updates for the 9000 first. Done? Check the LXnav website. I speak from experience. ![]() -- GC |
Do all the previous updates need to be put into the portable FLARM too? My unit shows 6.09 on startup, but only shows transponders, no FLARM targets. I may have taken it back to zero updates while trying to get 6.09 in. I hate this digital crap!
JJ |
On Tuesday, June 6, 2017 at 8:47:08 AM UTC-4, wrote:
Do all the previous updates need to be put into the portable FLARM too? My unit shows 6.09 on startup, but only shows transponders, no FLARM targets. I may have taken it back to zero updates while trying to get 6.09 in. I hate this digital crap! JJ If 6.09 shows, you should be good. Did you re-install your flarmcfg.txt file after the firmware update? Something may have gone astray when the old one was replaced. The other possibility, since pcas/transponders show and flarm doesn't, is that your flarm antenna may have a problem. I'd unscrew and screw it back in and see if that works. Cheers Dan |
Another FLARM update with no notice | Dan Daly[_2_] | Soaring | 1 | September 19th 16 04:30 PM |
Oudie Update Failed: Says not valid Win32 Application | Sean F (F2) | Soaring | 8 | October 1st 13 07:20 PM |
Flarm with Firmware 1.20 update | Robert Fidler[_3_] | Soaring | 49 | January 31st 12 03:40 PM |
FLARM UPDATE? | Stephen Michalik | Soaring | 6 | March 20th 11 04:24 PM |
CAI 302 security failed message | Joseph L. Hyde | Soaring | 9 | September 17th 04 06:47 AM |
