Oudie Update Failed: Says not valid Win32 Application
Old September 27th 13, 02:44 AM posted to rec.aviation.soaring
Sean F (F2)
Default Oudie Update Failed: Says not valid Win32 Application
FYI, the exe appears to be faulty...
Sean
Old September 27th 13, 04:05 AM posted to rec.aviation.soaring
glidergreg
Sean
Mine update works fine. Flew with it last Saturday.
Old September 27th 13, 03:07 PM posted to rec.aviation.soaring
Richard[_9_]
Sean
I just updated an Oudie and all worked OK. Try a different browser. 4.51.004
Richard
www.craggyaero.com
Old September 27th 13, 03:24 PM posted to rec.aviation.soaring
JohnDeRosa
Sean - I assume you are talking about the 4.5 update. Some significant changes in this release.
No problems getting it installed for 4.5 or any of the previous updates. Maybe your download was bad for some reason. Try, try again!
Poke around on http://forum.naviter.com to see if others are having issues and/or post a message.
Let us know what you find. Good luck.
- John
Old September 27th 13, 04:55 PM posted to rec.aviation.soaring
Sean F (F2)
Gremlins I guess. Will try again this evening!
Sean
Old September 27th 13, 09:26 PM posted to rec.aviation.soaring
Paul Remde
Hi Sean,
Did you copy the file to the root directory of the Oudie or try to run it on
your PC? You must either copy it to the root directory of the Oudie or put
it in the top level directory of a microSD memory card. Then reboot the
Oudie.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
___________________________
"Sean F (F2)" wrote in message
Sean
Old September 28th 13, 07:45 AM posted to rec.aviation.soaring
Make sure the file name has not changed. Last time I downloaded through chrome twice and it labeled the file as a copy with a (1) added in it would not load.
Kerry
Old October 1st 13, 07:20 PM posted to rec.aviation.soaring
JohnDeRosa
On Friday, September 27, 2013 3:26:58 PM UTC-5, Paul Remde wrote:
Did you ... try to run it on your PC?
Paul Remde
I think that Paul may be on to something. If you run the EXE on your computer you do get Sean's exact error message, "...blah is not a valid Win32 application."
Old September 28th 13, 01:37 PM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
For me, I tried to download it DIRECTLY to the root of the oudie, and when updating, it said it was corrupt. However I tried downloading it to my hard drive, then copying to the oudie, and that worked fine. Maybe that's it
PowerFLARM Files not valid with OLC Tim Taylor Soaring 5 June 22nd 13 05:30 AM
Oudie not making valid IGC files Tony[_5_] Soaring 2 May 31st 11 05:44 AM
Valid OLC log out of SN-10b Jim Archer Soaring 4 June 11th 08 11:46 PM
Valid OLC log out of SN-10b Jim Archer Soaring 0 June 11th 08 06:43 AM
Airworthiness Cert Still Valid? Carl Orton Owning 12 February 13th 04 10:21 PM
