hobo writes: The link you provided has no textual information regarding the prop, but there is a picture, dated 2001, of a surviving Corsair with a 4 blade prop. This prop may not be the original factory issue. When this question was first posted the first website on the Corsair I found was this: http://www.nasm.si.edu/research/aero...t/voughtf4.htm This is the Smithsonian's website and has a photo of a Corsair with a 3 bladed prop and this text: "The R-2800 radial air-cooled engine developed 1,850 horsepower and it turned a three-blade Hamilton Standard Hydromatic propeller with solid aluminum blades spanning 13 feet 1 inch." This website was my sole source for the claim that the Corsair had a 3 blade prop. Perhaps a 4 blade was later added, but it seems odd that a 3 blade was ever used if ground clearance was so pivotal to the whole design. Hobo, All the F4U-1 models had 3-blade propellers, with a 13'1" diameter. The later production models, the F4U-4 and F4U-5, with higher-powered engines, had 4 blade props with a 13'2" diameter, to absorb the extra power. (More than 800 HP in some versions.) So, its fair to say that they didn't go to a 4-blade prop to decrease ground clearance. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster -- |
All I Wanted For Christmas Were Inverted Spins | [email protected] | Aerobatics | 3 | December 29th 04 07:40 PM |
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") | Roberto Waltman | Home Built | 2 | October 29th 04 04:21 PM |
inverted spin recovery explanation | Alan Wood | Aerobatics | 18 | August 19th 04 03:32 PM |
Double covering fabric covered wings | [email protected] | Home Built | 9 | May 9th 04 08:39 PM |
Crooked or Wavy Trailing Edges of Wings and Control Surfaces | Larry Smith | Home Built | 3 | October 24th 03 02:31 AM |
