On Tuesday, June 20, 2017 at 8:36:17 AM UTC-7, ZP wrote:
I'm using batteries. two 7AH in parallel. There should be no issues w.r..t. battery. I also turned off all other components and it still behaved the same. I have not tried measuring the current draw. I'll try that to see the difference. but then, what would be the solution assuming the batteries are good? ZP, the squelch correlation is as you say interesting. You could spend time and money on 35-year-old electronics or pick up a replacement FSG60M for 50 Euros plus shipping. Even a newer 25kHz radio like Dittel FSG71M or Becker AR3201 will not be much more than that, but you'd need to build a panel adapter and change the multipin connector. http://www.segelflug.de/osclass/inde...&sCategory=110 Jim |
![]() http://www.segelflug.de/osclass/inde...&sCategory=110 Jim Jim, I'd like to buy the FSG-60M, but can't figure out to do that. I live in the US. |
On Wednesday, June 28, 2017 at 4:01:43 PM UTC-7, ZP wrote:
http://www.segelflug.de/osclass/inde...&sCategory=110 Jim Jim, I'd like to buy the FSG-60M, but can't figure out to do that. I live in the US. PM sent. Jim |
Dittel Fsg-5 radio | [email protected] | Soaring | 0 | July 21st 16 06:24 PM |
Dittel FGS50 issue and OAT Indicator | [email protected] | Soaring | 1 | August 16th 12 11:13 AM |
reversed polarity to Dittel issue | Sam Zimmerman | Soaring | 5 | April 16th 10 02:56 AM |
Wanted: Walter Dittel FSG60M | [email protected] | Soaring | 0 | April 21st 08 02:06 AM |
Dittel FSG60M radio and cradle for sale | [email protected] | Soaring | 2 | May 9th 06 09:08 AM |
