1987 Cobra Trailer Brake drum removal
Old June 24th 17, 04:30 PM posted to rec.aviation.soaring
Default 1987 Cobra Trailer Brake drum removal
Bolt appears welded to axle arm. Cannot remove spindle either.
Old June 24th 17, 05:51 PM posted to rec.aviation.soaring
Papa3[_2_]
I've worked on a number of these over the years, so I can't remember exactly which version is which. But, I would start with finding part numbers and hitting Google. There are a number of catalogs available online that show the components and in some cases very nice service instructions. It sounds like your version may be one of the earlier ones where the brake backing is integral to the spindle. It may not in fact be possible to remove.
Of course, Spindleberger is probably the best bet...
P3
AFAIK, if you're looking at the backing plate and spindle, you've gone as far as you can go without cutting/welding. Assuming the entire assembly didn't get hot enough to anneal/soften the spindle, why do you need to do any more disassembly? Replace or reline the shoes, think about replacing the springs, inspect the bearings/grease seals and replace if necessary, repack with grease, and put it all back together.
Chip Bearden
"JB"
Cobra trailer brake heating up Eric Greenwell[_4_] Soaring 14 August 14th 18 05:48 AM
Brake Drum needed for a 1984 Cobra Nick Kennedy Soaring 4 June 27th 15 03:29 AM
FS Cobra brake drum w/new bearing Hartley Falbaum[_2_] Soaring 1 December 3rd 11 01:05 PM
Source for Cobra Trailer Brake Shoes Chip Bearden[_2_] Soaring 1 September 22nd 10 02:48 AM
Older Cobra trailer brake oscillation Brian Bange[_2_] Soaring 9 March 10th 09 07:41 PM
