PW-5 longitudinal pitch oscillation
Old September 8th 17, 04:29 AM posted to rec.aviation.soaring
Default PW-5 longitudinal pitch oscillation
I didn't mention gust direction. I have been assuming it was a vertical gust lifting the tail, but I have no direct evidence for that.
In a nutshell, the comments offered seem to boil down to the following:
a) check flight habits for unintended movements
b) pull stick back to reduce tail-up pitching and roll into the thermal so indicated
c) ignore it
d) haven't seen/experienced it
e) moving CG forward would exacerbate the rocking effect of the tail-up pitching
I think about the rocking of a sailboat-- the retired coach says to move everyone toward the keel when dealing with waves so that the boat can rock fore and aft more easily (and thus lose less speed by bobbing a little more with the waves instead of slamming hard through the waves). From there I extrapolate that a wider weight spread toward the edges (fore and aft) can increase inertia and slow down oscillation about a central point.
Seems the thing to do is to add ballast on the next flight, hope for strong thermal activity, and report back to the thread. More weight will inevitably move the CG forward; can't move myself backward or I wouldn't be able to reach the controls!
Thanks,
Chris
Old September 8th 17, 03:37 PM posted to rec.aviation.soaring
Chris,
Some posters were confused over the title you used......believe you made a common mistake!
An aircraft pitches around its lateral axis, rolls around its longitudinal axis and yaws around its vertical axis.
Hope this helps,
JJ
Old September 9th 17, 05:08 AM posted to rec.aviation.soaring
Perhaps! What I describe is a pitch of the nose down and the tail up. Longitudinal seesawing (pitching) at the lateral axis.
Old September 9th 17, 12:46 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
All aircraft entering a thermal will do this, some more noticeably than
others.
Reasoning: as the glider flies into the thermal it enters a rising air
mass and the further it moves into this air mass, the faster the vertical
movement becomes. The effect on the glider is that its effective AOA is
reduced by the air's vertical velocity (draw a vector diagram and this
becomes obvious), which in turn means that the wing no longer supports
all the glider's weight. The effect of trim means that the glider will
automatically pitch down and speed up to regain lift.
The combination of this small forward acceleration plus the upward
acceleration as to enters progressively faster air is what you feel as
"the surge" when you enter a thermal.
What you see and feel depends on what you're flying. In my Libelle I
don't particularly notice the pitch down, and anyway it may be masked as
I'm pitching up to slow down from inter-thermal cruise speed or even
faster flight through the sink surrounding the thermal, but the surge
forward and up is quite easy to feel.
The most obvious demonstration of this that I've seen was shown by an A/1
competition model glider of around 4 feet span, even when it was 50-60 m
overhead. When entering a strong thermal it would pitch down quite
rapidly and about as steeply as a helicopter does after takeoff when its
pilot is in a hurry to get moving before returning to its normal trimmed
attitude as it entered the core of the thermal. Like all free flight
models of its era, its trim was set before launch and remained so
throughout the flight, so this strong pitch down was not due to trim
changes.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 9th 17, 06:19 PM posted to rec.aviation.soaring
becomes obvious)...
Seems the opposite to me. The rising air hits the wings from below, and thus at a higher AOA. This increases the lift on both the wing and the tail, but more so at the tail. This is what positive stability means. The glider then behaves just like after raising the nose momentarily and then letting go of the stick: it pitches nose down. It's not the trimmed speed it is seeking per se, it is the trimmed AOA. Thus in the thermal entry it pitches nose-down despite the speed being normal. Once the glider accelerates upwards due to the rising air, the vertical motion relative to the air returns to normal, and the normal pitch attitude relative to the horizon will be restored on its own. The more pitch-stable the glider (and yes this is called "longitudinal stability" IIRC?), the stronger this pitching effect should be. Maybe that's why I haven't noticed it in my gliders, since I have the CG near the rear end of the range, i.e., weak stability.
Old September 9th 17, 06:25 PM posted to rec.aviation.soaring
others.
reduced by the air's vertical velocity ...
Seems the opposite to me. The rising air hits the wings from below, and thus at a higher AOA. This increases the lift on both the wing and the tail, but more so at the tail. ("More so" in the sense of the strength of the resulting pitching moments around the CG.) This is what positive stability means. The glider then behaves just like after raising the nose momentarily and then letting go of the stick: it pitches nose down. It's not the trimmed speed it is seeking per se, it is the trimmed AOA. Thus in the thermal entry it pitches nose-down despite the speed being normal. Once the glider accelerates upwards due to the rising air, the vertical motion relative to the air returns to normal, and the normal pitch attitude relative to the horizon will be restored on its own. The more pitch-stable the glider (and yes this is called "longitudinal stability" IIRC?), the stronger this pitching effect should be. Maybe that's why I haven't noticed it in my gliders, since I have the CG near the rear end of the range, i.e., weak stability..
Old September 9th 17, 11:17 PM posted to rec.aviation.soaring
others.
vertical movement becomes. The effect on the glider is that its
effective AOA is reduced by the air's vertical velocity ...
If it was a body of air all rising at the same speed I'd agree, but in as
it enters a thermal the vertical velocity will be increasing as the
glider heads for the core, IOW its facing a continous disturbance which
has two components. One is the vertical velocity that the glider has
acquired from the air its just passed through. The second is the effect
of flying into air with a still higher vertical velocity.
If it was in a parcel of air with the same vertical velocity I'd agree
with you, but it ain't: its flying onto steadily increasing vertical
velocity as it approaches the thermal core, so if things are as you
describe, you'd expect the glider to be pitching up. As that's not what
we see and feel, there must be something else acting on it, which I think
is the effect of flying into an increasing velocity gradient is to reduce
the effective AOA of the wing. Of course in reality it affects both wing
and tail, but its effect on the wing is a little bigger because the wing
gets to the higher velocity rising air before the tail does. Granted its
a small effect, but I think its enough to cause the nose to drop/tail to
rise.
Yes, you're right there. I should have made that clearer.
Yes, that makes sense. My CG is pretty much in the middle of the
permitted range.
The force set up in the model will also be different: free flight gliders
normally have the CG at 52-55% of the wing chord, use a lifting section
on the tailplane and, yes, they are stable with a lifting tail. Almost
all designs operate with the wing at a Cl of around 1.2 and the tail at a
Cl of around 0.2. This puts the wing at an AOA of about 4 degrees more
than the tail, which keeps this layout stable with fast vertical upset
recovery. The tail is much bigger than on a sailplane - about 15-18% of
the wing area and, as a nice to have, most of the favoured tail sections
give minimum drag at a Cl of 0.2 - a nice bonus, since the tail is also
doing work against gravity as well as keeping the glider stable.
org |
Old September 14th 17, 02:10 AM posted to rec.aviation.soaring
So I increased the ballast weight in the PW-5 from parachute + 20 pounds to parachute + 40 pounds. The pitch stability increased noticeably, i.e. uncommanded nose-down excursions diminished.
Thanks all; I've enjoyed reading about model gliders and changes upon entering thermals.
Older Cobra trailer brake oscillation Brian Bange[_2_] Soaring 9 March 10th 09 07:41 PM
Wing Bending Oscillation jcarlyle Soaring 18 February 21st 06 04:37 PM
$30,000 pitch links Stuart Fields Home Built 3 January 16th 06 02:13 AM
$30,000 pitch links Stuart Fields Rotorcraft 7 January 15th 06 07:00 PM
Propellor pitch ... Bob Noel Owning 2 July 29th 03 04:30 AM
