IS-28B2 Twin Lark shock absorber replacement/rebuild
Old October 15th 17, 06:40 PM posted to rec.aviation.soaring
Default IS-28B2 Twin Lark shock absorber replacement/rebuild
Hey all, I called Blannik USA and they sell a rebuild kit for 500$ I'm thinking of getting one. The L-13 has the same shock absorber then the twin lark. I hope this helps. Unless you're just trying to replace the donuts. I'm in the same predicament with a1977 twin Lark.
Christian
Wurtsboro, NY
Old October 16th 17, 07:26 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Here are some pictures of the rebuild that my club did a few years back on an L23. You might find it useful. The first go at the rebuild and it didn't hold pressure. We found out some seals were reversed. Keep track of the order of things as you tear it apart! http://aviation.derosaweb.net/#blanik
Best of luck, John
IS-28B2 Twin Lark - Service Life Extension Program Pat McCartan Soaring 77 December 22nd 20 05:30 AM
IS-28B2 Twin Lark Factory Contact Pat McCartan Soaring 0 October 27th 13 09:19 PM
IAR IS-28B2 Twin Lark Manuals Needed Markus Graeber Soaring 3 July 8th 12 10:54 AM
IS-28B2 Twin Lark status Greg Arnold[_2_] Soaring 4 June 17th 08 03:34 PM
Looking for a Lark IS-28B2 or IS-32 [email protected] Soaring 3 June 2nd 06 06:35 AM
