Max Weight of Non Lift Producing Components
Old November 30th 17, 05:07 PM posted to rec.aviation.soaring
Tony[_5_]
Default Max Weight of Non Lift Producing Components
We weighed everything together and then the wings. Felt that was easier than trying to hold the fuselage with tail attached upright and on the scales.
Old November 30th 17, 05:53 PM posted to rec.aviation.soaring
Kevin Neave[_2_]
So what does the main pin(s) count as?
KN
scales.
Old November 30th 17, 06:15 PM posted to rec.aviation.soaring
BobW
KN
scales.
Try flying without it/them in place and get back to the group how it went!
More seriously, and structurally, it/they are part(s) of the wing.
Bob W.
This email has been checked for viruses by AVG.
http://www.avg.com
Old November 30th 17, 07:06 PM posted to rec.aviation.soaring
Dan Marotta
Part of the wings, yes, but certainly not lift generating.Â* But you
can't do without them...
KN
and on the scales.
went!
Bob W.
http://www.avg.com
Dan, 5J
Old November 30th 17, 07:07 PM posted to rec.aviation.soaring
BGA has a concession which allows for non-aerobatic flights to exceed the maximum weight of non-lifting parts by 3%, so my that margin it should be fine.
Does anyone know, how exceeding that non-lifting weight influences the flutter of the wing?
Stefan
Old November 30th 17, 07:26 PM posted to rec.aviation.soaring
Tango Whisky
No, it doesn't influence flutter. Flutter is controlled by the eigenfrequencies of the wing.
Old December 1st 17, 12:44 PM posted to rec.aviation.soaring
Kiwi User
Its more a structural thing than load related.
Increasing surface torsional stiffness delays the onset of flutter and
putting the CG of the flying surface in front of the torsion axis damps
it out.
Martin | martin at
Gregorie | gregorie
| dot org
Old December 1st 17, 07:00 PM posted to rec.aviation.soaring
CindyB[_2_]
For the non engineers that might read this..... a loading illustration
using two examples:
Use a (really long)tongue depressor and white glue to glue a hollowed out eggshell to the half span point. Let it dry. Take a wing tip and do anything you like to shake the egg off the stick. Not enough mass in the eggshell to part it from the stick. Safe scenario = under max non-lifting parts weight.
The worst case scenario is the same eggshell full of heavy stuff. Mercury would be great - but its impractical. Imagine it. Load that egg (fiberglass shell) to the max, and then introduce a bunch of G's via centrifical or gust(rotor flight)force. The eggshell will rip off the stick(spar). Or, the stuff inside the shell will rupture it and leave the scene - think an over-max-payload person attached to max 242 lb. (110 kg) seat belt attaching points.
There are recurring discussions about how much margin designers provide for protection from this and that (max non lifting, Vne, gust loads, seatpan loads). My response is always - do you know the life history of this pretty fiberglass? The controlrod end play? The hingepoint tightness? How many times someone flew it how close to/over Vne due to an antique instrument or partially plugged pitot line? I am not in favor of flying beyond manufacturer's limits for anything.....
thanks for the many contributors to good info on this thread.
Cindy B
Old December 1st 17, 08:34 PM posted to rec.aviation.soaring
Bob Kuykendall
designers provide for protection from this and that...
One of the more high-profile examples is this RV-10 airplane for which the amateur builder arbitrarily increased the gross weight by a hundred pounds. Designer Dick Vangrunsven rightfully took issue with this practice:
https://www.facebook.com/notes/vans-...37594966250883
...I am not in favor of flying beyond manufacturer's limits for anything...
That's the best plan!
--Bob K.
Old November 30th 17, 11:44 PM posted to rec.aviation.soaring
Bob Kuykendall
Very incisive question! That's a good demonstration of how the mass of non-lifting is a reasonable metric for the approximation of wing main spar maximum bending moment, but is still just an approximation.
At issue is that using a maximum mass of non-lifting parts to limit the wing spar bending moment is only valid when any mass added to the wings is distributed spanwise according to the wing lift distribution. So if for whatever reason you add a bunch of mass to the inboard ends of the wings (depleted uranium root ribs maybe?), you can be within the allowable non-lifting mass and within the load factor envelope, but still develop excessive wing spar bending moment.
Bottom line: Respect mass limits to the spirit and the letter of the published values. And if you want a glider with lots of non-lifting mass margin, build an HP-24. The one we finished last summer has an empty non-lifting mass of ~220 lbs (ready to fly with batteries, instruments, 24 ft^2 O2 bottle, etc) and a maximum of ~605 lbs, yielding a payload of ~385 lbs for pilot, parachute, FES, electric self-launch, BRS, etc.
--Bob K.
Fiberglass cloth weight vs 'finished' weight Fred the Red Shirt Home Built 12 April 5th 08 05:24 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 10:26 PM
How much weight will 15 ft.³ of helium lift? John Doe Home Built 1 December 3rd 04 05:07 PM
Crosswind components James L. Freeman Piloting 25 February 29th 04 02:21 AM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 05:20 AM
