On Saturday, February 3, 2018 at 3:51:27 PM UTC-5, Charles Longley wrote:
Does anyone have a source for metric aircraft countersunk machine screws? Similar to MS24693S28. They need to be aircraft hardware store screws have the wrong taper on them. This is for Blanik L-23 & L-33’s. ----- I went through this a couple months ago. As noted above, metric countersunk screws have a 90 deg countersink, and of course there are different kinds of heads like flat or oval. I wasn't able to find a single supplier that had everything I needed, so ended up ordering some from Mr Metric (aka Mountz) and others from Bel-Metric. Needless to say I bought a few extra of each size! Good luck, Brian |
On Wednesday, February 7, 2018 at 5:44:51 PM UTC-8, wrote:
On Saturday, February 3, 2018 at 3:51:27 PM UTC-5, Charles Longley wrote: Does anyone have a source for metric aircraft countersunk machine screws? Similar to MS24693S28. They need to be aircraft hardware store screws have the wrong taper on them. This is for Blanik L-23 & L-33’s. ----- I went through this a couple months ago. As noted above, metric countersunk screws have a 90 deg countersink, and of course there are different kinds of heads like flat or oval. I wasn't able to find a single supplier that had everything I needed, so ended up ordering some from Mr Metric (aka Mountz) and others from Bel-Metric. Needless to say I bought a few extra of each size! Good luck, Brian Brian Mil Spec screw on McMaster Carr are metric and have the 100 deg countersink.. Richard www.craggyaero.com |
I looked at the McMaster screws and they’re the wrong head size for Blanik’s.
On Thursday, February 8, 2018 at 10:19:25 AM UTC-8, Richard Pfiffner wrote:
On Wednesday, February 7, 2018 at 5:44:51 PM UTC-8, wrote: On Saturday, February 3, 2018 at 3:51:27 PM UTC-5, Charles Longley wrote: Does anyone have a source for metric aircraft countersunk machine screws? Similar to MS24693S28. They need to be aircraft hardware store screws have the wrong taper on them. This is for Blanik L-23 & L-33’s. ----- I went through this a couple months ago. As noted above, metric countersunk screws have a 90 deg countersink, and of course there are different kinds of heads like flat or oval. I wasn't able to find a single supplier that had everything I needed, so ended up ordering some from Mr Metric (aka Mountz) and others from Bel-Metric. Needless to say I bought a few extra of each size! Good luck, Brian Brian Mil Spec screw on McMaster Carr are metric and have the 100 deg countersink. Richard www.craggyaero.com woops the 100 deg was on the English cap screws. |
Fairey Long-range Monoplane pics 2 [4/9] - Like the first machine, it is fitted with a Napier Lion engine. Refinements have been added to this second machine, such as the spats over the undercarriage wheels.jpg (1/1) | Miloch | Aviation Photos | 0 | January 6th 18 04:31 PM |
Blanik screws? | Wade G | Soaring | 10 | March 28th 16 03:03 AM |
Metric Aircraft Hardware | [email protected] | Soaring | 2 | November 27th 07 06:23 AM |
FAA Screws Up Again | BushOKDemocratsSTUPID | Instrument Flight Rules | 2 | March 22nd 06 10:39 PM |
Metric Aircraft Nuts and Bolts | John Scott | Soaring | 6 | December 14th 05 08:54 PM |
