Worried about a leading edge crack in the fiberglass wing laminate ofmy PW-5
Old February 12th 18, 01:51 PM posted to rec.aviation.soaring
Default Worried about a leading edge crack in the fiberglass winglaminate of my PW-5
Â*"What would be wrong with, say, doubling the wheel base length?"
if you visit the MM Fabrication website and find the page with WingRigger options, you will see that it IS offered with a wide-track chassis. The bottom tube that holds the hardened chrome axle is seven inches longer and incorporates three linear bearings instead of the two in the standard chassis. The axle is also correspondingly longer. Stability is improved, although few customers opt for this choice. The wide-track is standard on WingRiggers sold for large gliders, but is available for an additional $75.
leading edge templates glider[_2_] Soaring 6 August 25th 10 10:43 PM
Wing Leading Edge Refinishing Jan Eldem[_2_] Soaring 4 June 17th 08 02:40 PM
Leading edge protection search Tim Hickey Home Built 0 June 28th 04 02:45 AM
-7 wing leading edge 'glitch' ? Charlie England Home Built 0 March 7th 04 12:27 AM
leading edge flaps Arquebus257WeaMag Military Aviation 105 January 14th 04 04:11 AM
