Worried about a leading edge crack in the fiberglass wing laminate ofmy PW-5
Old February 12th 18, 02:07 PM posted to rec.aviation.soaring
Default Worried about a leading edge crack in the fiberglass winglaminate of my PW-5
What would be wrong with, say, doubling the wheel base length? Wouldn't that at least mitigate the risk of a spill in situations where one can't turn the trailer into the wind?
Sorry to hear the story. Sounds like a knowledgeable person needs to check the structure.
A bigger rigger wheel base might get in the way when you try to get the wing near the glider to slide it into the trailer and remember, you are trying to keep something that likes to fly from flying in a gust. My guess is there is no practical way to make it big enough to fix the problem.
If the wind conditions are sporty, the tricks I've used are some combination of keeping the wind horizontal as long as possible, turning the trailer into the wind, finding a sheltered location, making a sheltered location with a big vehicle, getting some friends to help, and waiting for a lull in the wind.
I guess this is a part of gliding. To expect one person with any normal rigger to always work without precautions is optimistic. Just like in sailing, the wind is going to get respect one way or the other.
Good luck on the repair.
Old February 12th 18, 03:43 PM posted to rec.aviation.soaring
JS[_5_]
As others have suggested to the OP: Get the damage assessed by someone experienced in maintaining composite aircraft.
Not necessarily a factor here, but something noticed while riggers are used.. Some pilots like to have very little weight at the spar, so they aren't lifting much. This would be very easy to do with a wing as light as the PW5.
Having little weight in your hands can allow a casual grip on the spar. If there is a bump or a wind gust, this could lead to loss of control.
I'd suggest having sufficient weight at the spar to make you hold on.
I've only rigged a PeeWee the old fashioned way, but perhaps will get a chance to rig one in the next couple of weeks using the rigger kindly donated by Wolf-Dietrich Weber.
Old February 12th 18, 03:47 PM posted to rec.aviation.soaring
I've been solo rigging since 1982 almost every time I fly (originally my LS-3 but for the last 26 years, my ASW 24). I haven't built any WingMates in a while (maybe in the future) but one of the selling points was the ability to use it on any terrain, including plowed fields. It's actually more stable, easier on my body, and doesn't take much, if any, more time than if I'm using a crew.
But...I'm VERY careful in the wind. I use some of the same tricks mentioned plus one or two that are specific to my design (e.g., lowering the wing as far as possible until it's horizontal). But basically if the wind gets too strong and/or gusty, I ask someone to help. They don't have to lift anything! Big point. All they have to do is stand by the wingtip in case the wind tries to blow it over when the wing goes vertical. I've never damaged it in wind but I've had a couple of close calls.
If you have doubts about how much wind is too much, get someone to help. After 35 years of solo rigging, I'm actually more inclined to ask for that quick assist to "just stand there and push back on the wingtip if it starts to topple over" than I used to be.
Chip Bearden
leading edge templates glider[_2_] Soaring 6 August 25th 10 10:43 PM
Wing Leading Edge Refinishing Jan Eldem[_2_] Soaring 4 June 17th 08 02:40 PM
Leading edge protection search Tim Hickey Home Built 0 June 28th 04 02:45 AM
-7 wing leading edge 'glitch' ? Charlie England Home Built 0 March 7th 04 12:27 AM
leading edge flaps Arquebus257WeaMag Military Aviation 105 January 14th 04 04:11 AM
