Goop / caulk recommendations
Old March 14th 18, 07:15 PM posted to rec.aviation.soaring
sisu1a
Default Goop / caulk recommendations
On Wednesday, March 14, 2018 at 10:22:11 AM UTC-7, Jonathan St. Cloud wrote:
My trailer arrived with two soft solar chargers attached to the roof top via a sort of caulk/goop. Two years later the trailer is leaking under the solar panels. Looking for a recommendation for a goop or caulk that is white or clear, and can withstand the sun and heat of the Western USA flying spots?
Sikaflex 295 is a UV resistant sealant/adhesive
https://www.merrittsupply.com/produc...e-and-sealant/
3M makes one too, called 4000 UV
https://www.westmarine.com/buy/3m--4...96?recordNum=5
Loctite has their own version cleverly named Marine Sealant
https://www.homedepot.com/p/Loctite-...6891/206156418
If you use a paintable formula like the first two you can also put a UV protective topcoat over the sealant which would extend its exposure limit.
PDA Recommendations Jim White[_4_] Soaring 16 January 8th 09 09:29 PM
DME recommendations mindenpilot Owning 27 April 11th 05 05:23 PM
Recommendations - near FLL Hilton Piloting 2 March 16th 05 06:04 AM
CHT recommendations Dude Owning 3 December 26th 04 05:07 PM
MFD recommendations Richard Kaplan Owning 13 January 27th 04 04:04 PM
