Confusing SSA hand signals that should be changed
Old March 27th 18, 11:53 PM posted to rec.aviation.soaring
Tango Eight
Default Confusing SSA hand signals that should be changed
Kirk makes good points.
Here's what we do at Post Mills. We've made converts out of three other clubs in the region. It works well.
Our signal to take up slack is to level the wings of the glider. The wing runner "confirms" this by giving the take up slack signal as slack taking proceeds. As slack comes out, wing runner raises arm vertically, wing stays level. When ready to begin the launch, the glider gives a rudder wag, confirmed by the wing runner windmilling his arm. The tow pilot acknowledges with a brief rudder wag, then begins the take off.
Efficient, water ballast compatible, easy for everyone involved to see and understand. Why isn't the SSF teaching this?
best regards,
Evan Ludeman / T8
Old March 28th 18, 12:16 AM posted to rec.aviation.soaring
SoaringXCellence
This is the same thing we do at WVSC.
Old March 28th 18, 02:14 AM posted to rec.aviation.soaring
kirk.stant
best regards,
Evan Ludeman / T8
I like your way of doing it. Breaks the launch into distinct, unambiguous sequences with little chance of confusion, and addresses the water ballast equaling issue that inexperienced wing runners can screw up. And makes it obvious that a glider on the grid with level wings is hooked up and could move at any time. Similar to race launches where you go as soon as the rope is tight. Still have to beat into the wing runners not to signal takeoff until they see the rudder waggle. Also, if at any time during the preparation to launch the wing runner sees conflicting traffic, putting the wing down automatically stops the launch.
I'm going to see if I can get our club to try it.
Meanwhile - SSF, are you reading this? I think it's time to re-visit our procedures!
Kirk
66
St Louis Soaring Assn.
Old March 28th 18, 02:33 AM posted to rec.aviation.soaring
Dave Springford
Why the rudder waggle? What's its purpose? The only country in the half dozen countries in which I have flown that does a rudder waggle is the US.
From the towplane, I can barely see an ASW-27's rudder waggle in the vibrating mirrors. It also means that as a towpilot I am focused on my mirrors to ensure I don't miss the waggle instead of the circuit and traffic around me prior to take-off.
In Canada, the standard take-up slack and all-out signals are provided by the wing-runner after receiving a thumbs-up from the pilot.
As someone else mentioned up-thread. If the pilot is not happy about launching at that instant, pull the yellow knob.
Old March 28th 18, 02:41 AM posted to rec.aviation.soaring
We in Australia use the wing runner for all signals, the launch commences when the glider pilot gives a thumbs up to the runner,
who then levels the wings and waves his arm below the waist as a take up slack signal, then when the rope is tight, waves his arm above his head.
Never seen any problems with this practice.
Old March 28th 18, 02:49 AM posted to rec.aviation.soaring
Tango Eight
Because we're running a club and training operation, not a contest launch.
There are plenty of circumstances in which student plus instructor might need an extra five seconds to sort something out. Absent the rudder wag, your only recourse at "all out" is hit the release. That's not very efficient.
best,
Evan Ludeman / T8
Old March 28th 18, 01:45 PM posted to rec.aviation.soaring
My old club used to work with the Civil Air Patrol, supplying towplane, gliders and sometimes glider pilots to give cadets orientation flights. One disagreement over signals led to some pretty heated discussions.
Our club practice was to keep the wing on the ground until slack was removed glider pilot gave the thumbs up and the runner checked the pattern etc. He would then raise the wing. Rudders were waggled at both ends and if the runner felt it was safe gave the launch signal. The thought process was that it was easy for the tug pilot to see the wing's position. If the wing was down, stand by. CAP insisted that the wing should be raised to indicate the tug could take up slack citing their (and SSA's?) wing runner course. The problem was that the mix of tug and glider pilots varied. Sometimes one or both being ours, sometimes theirs. I've seen it done both ways. It seems to me that a takeoff commencing when the glider pilot isn't ready is less likely the way we did it. If the wing is up, the glider pilot is ready. But, when in Rome...
The FAA handbook says "Pilot ready, wings level — when the glider pilot is ready for takeoff, a thumbs up signal is given and the wing
runner will level the wing to the takeoff position".
Old March 28th 18, 01:28 PM posted to rec.aviation.soaring
best regards,
Evan Ludeman / T8
We use the following;
Wing down: Stop. Not ready to go.
Wing rocking: shoulder to knee- Ready to go- take up slack
Wings level. Ready to go- take off- all out.
All are visible in shaking mirror and not easily mistaken
If at any time operation needs to stop. - Wing down.
All pilots trained from the get go to pull the release if rope comes tight with wing down.
We teach rudder wag for purposes of standardization so our pilots know what may be expected at other sites.
FWIW
UH
Old March 28th 18, 08:57 PM posted to rec.aviation.soaring
S2
The only justification for taking up slack with the wingtip on the ground is that it leaves the wingrunner with both hands free to give that much-deprecated stop signal.
As a towpilot, I'm very reluctant to take up slack while the wingtip is on the ground. It looks too much like a glider with nobody in it.
I'm with Evan on this one.
Old March 28th 18, 09:38 PM posted to rec.aviation.soaring
Chris Rowland[_2_]
on
The UK BGA has specified a standard set of signals that make sense, work
and are used universally. They have the huge advantage that you can go to
a different club and get or help with a launch with minimal confusion or
misunderstanding.
There are differences between clubs, for example Sutton Bank use a separate
signaller while at Booker the wing runner does the signalling. The signals
are the same. We were able to adapt within a few seconds.
Doesn't the USA have something similar?
Chris
Hand Propping_Adult - Fw_ Hand Propping.eml Ducky[_3_] Aviation Photos 2 June 6th 08 02:27 AM
A little confusing up in Newark Gizmo Piloting 0 May 23rd 08 02:35 AM
Confusing instructions from ATC.. looking for a concise response Terence Wilson Instrument Flight Rules 7 April 1st 08 06:56 PM
Tow Signals Ramy Soaring 58 October 19th 06 04:46 AM
kit plane pricing confusing natureboy Home Built 3 September 12th 04 06:32 PM
