Landing with reduced airbrake
Old May 16th 18, 03:27 AM posted to rec.aviation.soaring
Default Landing with reduced airbrake
I was taught to land the glidr in the same attitude as it sits on the ground. I have always followed this practice, and have 300 landings
with no problems. One particular DG 1000 owning club does not like me not holding off the glider until it stalls on, resulting in a tail wheel first landing.
I find this attitude plain stupid.
Old May 16th 18, 03:37 AM posted to rec.aviation.soaring
Richard McLean[_2_]
Thanks Mike. Do you ever find that if using more than 1/2 air-brake you need to reduce it before the flare? The theory is that slightly tail first is best, so that you're definitely low-energy & the nose pitches down rather than the reverse .. but I land my Astir 2 point if I can!
Cheers,
Richard
Old May 16th 18, 04:35 AM posted to rec.aviation.soaring
George Haeh
Newer gliders with powerful air brakes will lose airspeed rapidly in the flare. Flaring too high or from an inadequate airspeed, especially with powerful air brakes full on, can end in a hard landing.
Perhaps the tailplane in the taller gear variants of the DG-1000/1 produces more lift as it rotates around the main gear to cushion the tailwheel contact.
A less tall gear does increase the possibility of a tailwheel first landing.
Another consideration is the amount of tail ballast carried.
Have you noticed if there's a difference with heavier or lighter pilots in the front seat?
It might be useful to have two experienced pilots, one to video and take notes, to do landings at various airspeeds and CGs to determine optimal landing parameters - and determine what to avoid.
Old May 16th 18, 04:47 AM posted to rec.aviation.soaring
Richard McLean[_2_]
Thanks for that George - yes, a bit of experimentation might be a good idea.
One of our most experienced pilots says the LS8 requires an airbrake reduction to avoid excessive tail-first landings, so perhaps it's the same with this configuration DG-1000.
Cheers,
Richard
Old May 16th 18, 04:49 AM posted to rec.aviation.soaring
Richard McLean[_2_]
And no, we've only just started flying the glider, so no observations about differing pilot weights/CG position as yet.
Cheers,
Richard
Old May 17th 18, 04:14 PM posted to rec.aviation.soaring
Papa3[_2_]
Cheers,
Richard
I owned an LS8 for about 13 years, so figure about 450-500 takeoffs and landings. I don't remember anything special about the flare and touchdown. The POH is very clear that with airbrakes fully extended one needs to carry additional airspeed and that a slip with full airbrakes is not recommended.. That said, I never had any trouble stuffing the glider into some fairly short spaces.
I can see a scenario where the pilot is coming in right at the minimum approach speed and full divebrakes, mis-judging the roundout, and hauling back on the stick resulting in a very firm arrival. But the same applies to other gliders. I once borrowed a friends ASW-20 (original version) and demonstrated a max-performance approach with full flaps. Roundout, touchdown, and "oh sh***" all in one smooth motion :-)
P3
Old May 16th 18, 06:03 AM posted to rec.aviation.soaring
I try to get the bulk of braking done during final, and to flare at about half brake. i havent however, had any problems with full brake landings.
I dont stress about not flying the glider on a bit either, and neverr have trouble with bounces.
I had a partciularly nasty experience in an old twin Astir, when a gust just after a fully held off landing lifted the nose and caused a very heavy landing, despite closing the brakes very quickly.
Kestrel 19 Airbrake Mod [email protected] Soaring 1 January 13th 14 06:06 PM
asw19 airbrake kit steve[_2_] Soaring 2 April 7th 11 08:32 PM
LS3a Airbrake question [email protected] Soaring 5 April 29th 08 03:10 AM
airbrake position while tied outside CK Soaring 18 January 19th 04 02:34 PM
airbrake question miso Military Aviation 17 December 4th 03 04:27 AM
