Landing with reduced airbrake
Old May 17th 18, 09:48 AM posted to rec.aviation.soaring
Jonathon May
Default Landing with reduced airbrake
At 06:36 17 May 2018, Bruce Hoult wrote:
On Thursday, May 17, 2018 at 1:43:09 PM UTC+12, Richard McLean wrote:
On Wednesday, 16 May 2018 22:21:48 UTC+8, Matt Herron Jr. wrote:
from my perspective, reducing airbrakes at 100' changes your glide
slop=
e and therefor aim point half way through final. So do you give up your
in=
itial aim point at 100', or do you have two aim points? Either option
seem=
s like a bad idea for students.
=20
Airbrake deployment should be a driven variable to maintain a correct
a=
pproach, not the other way around.
=20
Additionally, a shallower approach for the last 100' means you are
way
more susceptible to wind shear, as you don't have much "extra" glide to
rec=
over by closing the airbrakes.
=20
To me, it sounds like the tail strike problem is in the flair, not
use of airbrakes.
=20
Hi Matt, yes you give up the original aim point. This isn't ideal but
bet=
ter than damaging the aircraft? The debrief can cover off the reasons.
Lots=
of bad landings are the result of not accepting that you stuffed up your
o=
riginal aiming point & concentrating on the actual landing.
I'd think if you were so high turning final that you can't get back on to
a=
standard half brake approach by, say, 100m before crossing the fence
then
you've well and truly stuffed up the circuit. Especially in something
with
airbrakes as powerful as a DG1000 or Grob. You definitely should never be
p=
lanning to carry full brake all the way down the approach ... that leave
no=
thing in reserve for the unexpected.
Trick one
I have not flown the DG1001 neo yet but I have quite a lot of time in the
original DG1000,you need a step to get people in,if that is the angle for
2point landing them the newer versions going to land tail wheel first .
I have done hundreds of trial flights in an early DG500 that everyone said
was "over braked" ,in fact it could be .But as all I wanted was to get the
punters down safe without a hard landing I tend to add 5kns and gently fly
it on, on the main wheel.
The trouble with that is its not the correct method to teach landing to
pupils.
As I said tricky
My advice would be to buy a K21 or Duo xl ,they fly as you would expect.
Old May 18th 18, 02:40 AM posted to rec.aviation.soaring
Bruce Hoult
slop=
in=
seem=
=20
a=
=20
way
rec=
=20
use of airbrakes.
=20
bet=
Lots=
o=
a=
then
with
p=
no=
Trick one
pupils.
As I said tricky
Not necessary. All you need to do is fly close to the ground and gradually slow and increase the pitch until you are in the same attitude as you would be on the ground.
Assuming you have levelled out at the correct height for your undercarriage length it all works out just the same as any other glider. Main wheel is skimming just a few inches above the ground, once the AOA gets to the point that the tail wheel touches gently you physically can't increase the pitch more, and do the main will gently drop on.
Whether the glider is actually "stalled" at that point or not is irrelevant..
If you level out a DG1000 Club at the same height as you would a standard DG1000, and then slow until it stalls, then you're going to be dropping on hard from a foot up no matter what you do. Know how it looks out the window of your glider when it's on the ground!
Old May 18th 18, 03:09 AM posted to rec.aviation.soaring
Richard McLean[_2_]
glide
slop=3D
your
in=3D
option
seem=3D
=3D20
correc=
t
a=3D
=3D20
are
way
=3D
glide to
rec=3D
=3D20
=3D
use of airbrakes.
=3D20
but
bet=3D
reasons.
Lots=3D
you=
r
o=3D
on
t=
o
a=3D
fence
then
=3D
with
=3D
never
b=
e
p=3D
leave
no=3D
=20
Trick one
angle
f=
or
Kestrel 19 Airbrake Mod [email protected] Soaring 1 January 13th 14 06:06 PM
asw19 airbrake kit steve[_2_] Soaring 2 April 7th 11 08:32 PM
LS3a Airbrake question [email protected] Soaring 5 April 29th 08 03:10 AM
airbrake position while tied outside CK Soaring 18 January 19th 04 02:34 PM
airbrake question miso Military Aviation 17 December 4th 03 04:27 AM
