On Thursday, May 17, 2018 at 9:00:15 PM UTC+12, Jonathon May wrote:
At 06:36 17 May 2018, Bruce Hoult wrote: On Thursday, May 17, 2018 at 1:43:09 PM UTC+12, Richard McLean wrote: On Wednesday, 16 May 2018 22:21:48 UTC+8, Matt Herron Jr. wrote: from my perspective, reducing airbrakes at 100' changes your glide slop= e and therefor aim point half way through final. So do you give up your in= itial aim point at 100', or do you have two aim points? Either option seem= s like a bad idea for students. =20 Airbrake deployment should be a driven variable to maintain a correct a= pproach, not the other way around. =20 Additionally, a shallower approach for the last 100' means you are way = more susceptible to wind shear, as you don't have much "extra" glide to rec= over by closing the airbrakes. =20 To me, it sounds like the tail strike problem is in the flair, not the = use of airbrakes. =20 Hi Matt, yes you give up the original aim point. This isn't ideal but bet= ter than damaging the aircraft? The debrief can cover off the reasons. Lots= of bad landings are the result of not accepting that you stuffed up your o= riginal aiming point & concentrating on the actual landing. I'd think if you were so high turning final that you can't get back on to a= standard half brake approach by, say, 100m before crossing the fence then = you've well and truly stuffed up the circuit. Especially in something with = airbrakes as powerful as a DG1000 or Grob. You definitely should never be p= lanning to carry full brake all the way down the approach ... that leave no= thing in reserve for the unexpected. Trick one I have not flown the DG1001 neo yet but I have quite a lot of time in the original DG1000,you need a step to get people in,if that is the angle for 2point landing them the newer versions going to land tail wheel first . I have done hundreds of trial flights in an early DG500 that everyone said was "over braked" ,in fact it could be .But as all I wanted was to get the punters down safe without a hard landing I tend to add 5kns and gently fly it on, on the main wheel. The trouble with that is its not the correct method to teach landing to pupils. As I said tricky My advice would be to buy a K21 or Duo xl ,they fly as you would expect. Not necessary. All you need to do is fly close to the ground and gradually slow and increase the pitch until you are in the same attitude as you would be on the ground. Assuming you have levelled out at the correct height for your undercarriage length it all works out just the same as any other glider. Main wheel is skimming just a few inches above the ground, once the AOA gets to the point that the tail wheel touches gently you physically can't increase the pitch more, and do the main will gently drop on. Whether the glider is actually "stalled" at that point or not is irrelevant.. If you level out a DG1000 Club at the same height as you would a standard DG1000, and then slow until it stalls, then you're going to be dropping on hard from a foot up no matter what you do. Know how it looks out the window of your glider when it's on the ground! |
At 01:40 18 May 2018, Bruce Hoult wrote:
On Thursday, May 17, 2018 at 9:00:15 PM UTC+12, Jonathon May wrote: At 06:36 17 May 2018, Bruce Hoult wrote: On Thursday, May 17, 2018 at 1:43:09 PM UTC+12, Richard McLean wrote: On Wednesday, 16 May 2018 22:21:48 UTC+8, Matt Herron Jr. wrote: from my perspective, reducing airbrakes at 100' changes your glide slop=3D e and therefor aim point half way through final. So do you give up your in=3D itial aim point at 100', or do you have two aim points? Either option seem=3D s like a bad idea for students. =3D20 Airbrake deployment should be a driven variable to maintain a correc= t a=3D pproach, not the other way around. =3D20 Additionally, a shallower approach for the last 100' means you are way =3D more susceptible to wind shear, as you don't have much "extra" glide to rec=3D over by closing the airbrakes. =3D20 To me, it sounds like the tail strike problem is in the flair, not the =3D use of airbrakes. =3D20 Hi Matt, yes you give up the original aim point. This isn't ideal but bet=3D ter than damaging the aircraft? The debrief can cover off the reasons. Lots=3D of bad landings are the result of not accepting that you stuffed up you= r o=3D riginal aiming point & concentrating on the actual landing. I'd think if you were so high turning final that you can't get back on t= o a=3D standard half brake approach by, say, 100m before crossing the fence then =3D you've well and truly stuffed up the circuit. Especially in something with =3D airbrakes as powerful as a DG1000 or Grob. You definitely should never b= e p=3D lanning to carry full brake all the way down the approach ... that leave no=3D thing in reserve for the unexpected. =20 Trick one I have not flown the DG1001 neo yet but I have quite a lot of time in the original DG1000,you need a step to get people in,if that is the angle f= or 2point landing them the newer versions going to land tail wheel first |
Kestrel 19 Airbrake Mod | [email protected] | Soaring | 1 | January 13th 14 06:06 PM |
asw19 airbrake kit | steve[_2_] | Soaring | 2 | April 7th 11 08:32 PM |
LS3a Airbrake question | [email protected] | Soaring | 5 | April 29th 08 03:10 AM |
airbrake position while tied outside | CK | Soaring | 18 | January 19th 04 02:34 PM |
airbrake question | miso | Military Aviation | 17 | December 4th 03 04:27 AM |
