On 5/27/2018 8:17 AM, Jonathan St. Cloud wrote:
Was wondering if anyone knew the approximate weight of tehnD size steel 02cylinders that are used in Schliecher gliders? Thanks I just weighed 2 of them at 10.7 lbs. each. |
On Sunday, May 27, 2018 at 8:42:22 AM UTC-7, Dave Leonard wrote:
On 5/27/2018 8:17 AM, Jonathan St. Cloud wrote: Was wondering if anyone knew the approximate weight of tehnD size steel 02cylinders that are used in Schliecher gliders? Thanks I just weighed 2 of them at 10.7 lbs. each. Thanks much! |
Just a reminder that all cylinders are not necessarily alike. Twenty-five years ago I discovered that (at least then) my ASW 24 oxygen bottle holder was a REALLY tight fit for a steel bottle (D size, IIRC; my LS-3 was sized for an E bottle--same diameter but longer). That's when I learned that aluminum bottles with the same nominal diameter (4.3") were slightly larger and composite bottles larger still.
I can't find much online to confirm whether that's still the case. Most sources just list diameter as 4.3". But several do confirm that aluminum bottles are 4.37" dia. (possibly because the wall thickness is twice that for steel bottles). No big deal if there's some clearance in the mounting tube or you're using a clamp-type mount. A non-starter if--like mine--the molded in fiberglass tube is a "perfect" fit after some sanding (of the fiberglass tube, not the bottle). Chip Bearden |
Fiberglass cloth weight vs 'finished' weight | Fred the Red Shirt | Home Built | 12 | April 5th 08 04:24 PM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Piloting | 7 | May 27th 07 05:26 AM |
Oil in cylinder, other cylinder issues | Jim Burns[_3_] | Piloting | 2 | May 24th 07 05:26 AM |
Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 09:26 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
