Good lubricant for assembly
Old May 30th 18, 01:07 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Default Good lubricant for assembly
On Tuesday, May 29, 2018 at 2:39:59 PM UTC-7, jfitch wrote:
On Tuesday, May 29, 2018 at 1:03:41 PM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
Agreed.
Vaseline is better than dry or old lube.
Cheap and easy to get.
Easy to use.
If assembling for a season, maybe something better.
Keep in mind, very limited movement so lube quality is less of an issue..
Yes, some may say the "wings will fall off" if you use the wrong lube. In this case, not likely.
I can't agree with the "anything" specification. The main pins do not move, but the lift and drag pins clearly do work in flight, with considerable pressure on them. Any glider a few years old will show signs of wear, galling, or Brinelling on those pins. From this is seems to me that something with some extreme pressure ingredients is desirable.
My observations as well regarding wear. After replacing a set of lift pins I switched away from "Superlube" to a lithium based grease designed for high bearing pressures.
Craig
Old May 30th 18, 06:32 PM posted to rec.aviation.soaring
Papa3[_2_]
Hey Craig,
For what it's worth... Superlube with PTFE (the one in the tube many of us use) is NLGI rated GC-LB. Per the NLGI folks: "Grease packaging may display the code GC-LB, meaning that it meets the most demanding test standards for both chassis and wheel bearings. Grease products displaying this highest rating meet OEM requirements." Among other comments, it says "Wide temperature grease for use in components such as bearings, chassis and universal joints in passenger cars, trucks, and other vehicles under mild and severe duty.This includes vehicles operated under frequent stop-and-go service (buses, taxis, urban police cars, etc.), or under severe braking service (trailer towing, heavy loading, mountain driving, etc.) (see ASTM D4950)."
Just curious what the specs of the other grease you are using meets. Not doubting you, just looking for data.
P3
Old May 30th 18, 11:04 PM posted to rec.aviation.soaring
Craig Funston[_3_]
On Wednesday, May 30, 2018 at 10:32:54 AM UTC-7, Papa3 wrote:
Hey Craig,
P3
HI Eric,
I just switched to Lucas "Red 'n' Tacky". It has the same NLGI GC-LB rating.. I hadn't seen anything in the Superlube literature that talked about extreme pressure suitability. It's entirely possible I missed that.
https://lucasoil.com/products/grease/red-n-tacky-grease
Craig
7Q
Old May 30th 18, 11:33 PM posted to rec.aviation.soaring
Craig Funston[_3_]
Hey Craig,
P3
HI Eric,
I just switched to Lucas "Red 'n' Tacky". It has the same NLGI GC-LB rating. I hadn't seen anything in the Superlube literature that talked about extreme pressure suitability. It's entirely possible I missed that.
Craig
7Q
Eric,
30 seconds of googling produced a spec sheet for an extreme pressure version of Superlube. http://www.super-lube.com/tech-data-...re-ezp-92.html
Craig
Old May 31st 18, 01:21 AM posted to rec.aviation.soaring
Tom BravoMike
Hey Craig,
P3
HI Eric,
Craig
7Q
Eric,
Craig
It's even "Kosher Certified" - WOW! That has finally convinced me.
Old June 1st 18, 01:13 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Hey Craig,
P3
HI Eric,
Craig
7Q
Eric,
Craig
Of note: The Lucas "Red 'n' Tacky" has a Timken OK load rating of 60 lb whereas the Superlube has a lower rating of 40 lb.
My observations are that this type of high pressure sliding capacity along with corrosion resistance is what matters for pin longevity.
https://lucasoil.com/pdf/TDS_Red-Tacky-Grease.pdf
https://en.wikipedia.org/wiki/Timken_OK_Load
YMMV
Craig,
7Q
Lubricant for spar pins Jonathan St. Cloud Soaring 38 January 10th 18 04:29 PM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6973447.jpg [email protected] Aviation Photos 0 April 11th 07 02:43 AM
Best lubricant for Mechanical Tachometer Cable??? RonLee Home Built 3 January 4th 05 12:04 AM
