Kestrel 19 info wanted.
Old June 1st 18, 07:28 AM posted to rec.aviation.soaring
Default Kestrel 19 info wanted.
Should be better than 45 after reprofiling, my 17m DG200, same airfoil is 45 factory, the 17m kestrel was 43, and the 19m was 44.
Old June 3rd 18, 07:14 PM posted to rec.aviation.soaring
BruceGreeff
Hi Mike
Unfortunately when they built the 19m they did not understand
aerodynamics so well I suspect. So they added a metre of thick draggy
wing at the root, and left the relatively high lift wingtips in place.
So - what you get is lots of extra profile drag. Best I could get off
GPS traces on long final glides in winter when the air is nice and still
- a little under 1:46... Maybe it is that she is 40+years old (1971 was
a LOOONG time ago). Maybe I am pessimistic. With properly profiled
airfoil but without additional mylar seals on the flaps - only internal
seals. I can honestly claim 1:45 is an achievable glide ratio. On a good
day it is maybe 1 better. But I never counted on that. The single piece
canopy may improve the sealing enough to make a difference there - the
amount of noise the canopy generates indicates that it is a source of
significant drag.
Keith modified a T59D by reprofiling the entire wing, and removing the
outboard 1.5m on each side, and reprofiling that part with thinner,
lower incidence airfoil and polyhedral plus a winglet. That got the
owner more like 1:51 - but the cost to do it commercially would be
prohibitive.
Old June 4th 18, 12:54 AM posted to rec.aviation.soaring
Its is my recollection that 1/2 meter was added at the root and the tip.
Airfoils 101, a thicker airfoil has a wider but shallower low drag bucket.
LS-3a Polar Info. Wanted. Eric Nielsen Soaring 4 January 21st 16 01:26 PM
Color scheme info wanted. Kees Mies Piloting 13 November 12th 04 02:46 PM
Wanted Info on Narco Com 810 [email protected] Owning 1 July 18th 04 12:20 PM
Discus Info Wanted Scott Soaring 0 March 9th 04 05:59 AM
Wanted info on Buttercup Charlie Restoration 0 November 20th 03 05:03 PM
