Ventus ballast leak
Old September 8th 18, 05:01 PM posted to rec.aviation.soaring
MrT
Default Ventus ballast leak
On Saturday, October 9, 2010 at 1:21:53 PM UTC+2, wladkummer76 wrote:
Hi all,
Id like to ask for help here. My Ventus a SN143 right wing ballast is
leaking around the ballast valve actuator rod. I've contacted S&H but
no response so far. I do not know if a O-ring seal would fit in the
small recess.
Have anyone in this group experienced this problem?
Thanks to everyone
Hi,
I want to do the repair myself as I'm qualified - that way I can save some $ and gain some experience.
But it would nevertheless be good with some input from people who have already done similar repairs.
SH told me to follow the Maintenance manual, but in the Maintenance manual (April 1983) they only describe glass fibre repairs. For Carbon parts they say, that one should ask for instruction from the manufacture :-S
Thanks MrT
Old September 9th 18, 05:40 AM posted to rec.aviation.soaring
Mike C
Hi all,
small recess.
Thanks to everyone
Hi,
Thanks MrT
I did this on a Mini Nimbus that had carbon skins, under the watchful eye of my A&P. There are some photos of the procedure that may be helpful on the Mini Nimbus Yahoo Group. You will have to join the group for access though.
Mike
C85 Oil Leak Dick[_1_] Owning 2 May 2nd 07 11:00 PM
water ballast leak Robert Harvey Soaring 2 May 27th 05 03:49 PM
water ballast leak Robert Harvey Soaring 0 May 26th 05 10:33 PM
Oil leak Gene Seibel Owning 10 January 4th 05 02:57 PM
Oil leak mike regish Piloting 9 June 22nd 04 03:46 AM
