Car/Truck to pull glider trailer
Old September 10th 18, 08:52 PM posted to rec.aviation.soaring
2G
Default Car/Truck to pull glider trailer
On Monday, September 10, 2018 at 9:48:11 AM UTC-7, Dan Daly wrote:
Sorry for jumping in late to this thread ... is a class II hitch sufficient (assuming glider/trailer less than 2,000 lbs? Appreciate any advice. Jim
https://www.autoanything.com/towing/...tch-class.aspx
Many of our club members use Class I.
According to this, a Class II is comfortably ok:
https://www.drawtite-hitches.com/lea...towing-classes
I would not recommend a Class I, even if it technically met the specs (less than 2000 lb and less than 200 lb tongue weight). The reason is the length of the trailer - winds can increase the load seen by the hitch quite substantially.
Tom
Uvalde Worlds 2012 - trailer + truck help Tim[_2_] Soaring 0 October 24th 11 04:13 PM
Moving a glider with a U-Haul Truck [email protected] Soaring 11 February 10th 09 08:48 PM
Hauling a trailer by rail or car-carrier truck GM Soaring 11 April 18th 08 09:46 PM
truck + 5th wheel RV + glider trailer ?? Steve Koerner Soaring 16 March 27th 07 03:44 AM
Glider pull-up and ballast M B Soaring 0 September 15th 03 06:29 PM
