ASW-19 Maximum Weight
Old October 15th 18, 11:19 PM posted to rec.aviation.soaring
Ouroboros
Default ASW-19 Maximum Weight
On Monday, October 15, 2018 at 4:18:48 PM UTC-6, wrote:
On Monday, October 15, 2018 at 3:52:19 PM UTC-6, Paul Agnew wrote:
Has the glider had any repairs that upped the empty weight? My ASW19 can take up to 258# pilot and chute, with 10#s of weight in the tail.
The ASW19 is convertible to the 19B with some mods; brake moved to spoiler handle, friction trim, and Tost release support bolts, if my memory serves correctly.
Paul A.
Jupiter, Fl
The glider did have a gear up landing some time ago. It was also refinished at some point. The new empty weight is 609 pounds.
I'm still not understanding where this 805 number is coming from. Like UH, we initially thought the limit was because of the limit for non lifting parts, but neither of the two weight and balance documents we saw for the aircraft list what the non lifting parts actually weigh. Is it possible to somehow combine the max gross limit and non lifting part limit to come up with 805 pounds? I don't see how it is.
The type certificate data sheet also makes no mention of max weight of non lifting parts. I'm very confused.
Here is a direct link to the type certificate data sheet:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/3befadc9f249ca8d8625748e0055f922/$FILE/G36eu.PDF
Oops. Wrong account. That last post was me.
Maximum aircraft weight a carrier catapult can launch? J[_2_] Naval Aviation 6 June 1st 11 10:01 AM
Minimum amount of Maximum pilot weight Nyal Williams[_2_] Soaring 1 May 22nd 11 10:34 AM
Fiberglass cloth weight vs 'finished' weight Fred the Red Shirt Home Built 12 April 5th 08 04:24 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
