On Thursday, October 18, 2018 at 3:56:29 PM UTC-4, Ouroboros wrote:
I'd also like to know why this 805 pound dry weight limit isn't mentioned in the manual. I've now seen three other weight and balance calculations for ASW-19s and none of them compare dry loaded weights to 805 pounds, even though that would be the limiting factor for their max pilot weights. Kind of ticks me off that such an important number isn't in the manufacturers documentation. What does the flight manual say for this configuration? UH |
Here's a link to a copy of the manual:
https://drive.google.com/file/d/1TUV...w?usp=drivesdk I only see mention of a maximum all up weight and maximum non lifting parts. The manual does have a table for maximum water ballast carried depending on cockpit load, but again is only limited by max gross and non lifting parts. |
On Thursday, October 18, 2018 at 5:19:34 PM UTC-4, Ouroboros wrote:
Here's a link to a copy of the manual: https://drive.google.com/file/d/1TUV...w?usp=drivesdk I only see mention of a maximum all up weight and maximum non lifting parts. The manual does have a table for maximum water ballast carried depending on cockpit load, but again is only limited by max gross and non lifting parts. The manual(note it is for a 19B) is clear. If you have the weighing info that provides wing weight,in addition to total empty weight, you can determine the max pilot weight for that glider based upon max weight of non lifting components. The manual specifically describes fairly heavy pilot mass in the cockpit. If it is not a B, there is descriptive info on the Schleicher web site on how to do so. It is not a big deal. Been There Done That UH |
On Thursday, October 18, 2018 at 8:12:31 PM UTC-4, wrote:
On Thursday, October 18, 2018 at 5:19:34 PM UTC-4, Ouroboros wrote: Here's a link to a copy of the manual: https://drive.google.com/file/d/1TUV...w?usp=drivesdk I only see mention of a maximum all up weight and maximum non lifting parts. The manual does have a table for maximum water ballast carried depending on cockpit load, but again is only limited by max gross and non lifting parts. The manual(note it is for a 19B) is clear. If you have the weighing info that provides wing weight,in addition to total empty weight, you can determine the max pilot weight for that glider based upon max weight of non lifting components. The manual specifically describes fairly heavy pilot mass in the cockpit. If it is not a B, there is descriptive info on the Schleicher web site on how to do so. It is not a big deal. Been There Done That UH Info: https://www.alexander-schleicher.de/..._TM06AB_E..pdf Raises max mass of pilot to about 254 lb. UH |
That TN doesn't increase the max weight without water, which is the limiting number for this particular glider and the number that is not in the manual.
At 01:37 19 October 2018, Ouroboros wrote:
That TN doesn't increase the max weight without water, which is the limiting number for this particular glider and the number that is not in the manual. Unless I am missing something all you need to know is the particular gliders actual (not assumed manufactured) weight of the non-lifting parts. The max pilot (actually payload, pilot / parachute / ballast weights / onboard snacks etc) weight is then the lower of: a) Weight of the actual non-lifting parts subtract from the manuals max non-lifting parts weight of 230kg (507lbs). Or b) 115kg (253.4lbs) which the manuals max pilot weight. Or c) The max all up weight less the empty weight (very unlikely to come into play) This all assumes that the empty CofG limit is inside the manual limitations. The max weight without water is not relevant and most new aircraft don't list it. You know the max non-lifting parts weight (the critical point due to bending loads), and the max all up weight inc water (undercarriage/structural and flight stress loads), then the difference has to be all in the wings. The aircraft doesn't know if the wings weight is structure or water so is happy to fly! |
At 11:52 19 October 2018, Jonathan Walker wrote:
At 01:37 19 October 2018, Ouroboros wrote: That TN doesn't increase the max weight without water, which is the limiting number for this particular glider and the number that is not in the manual. ------------ Ill try again and see if it still chops off the end of each sentence!!! ------------ Unless I am missing something all you need to know is the particular gliders actual (not assumed manufactured) weight of the non-lifting parts. The max pilot (actually payload, pilot / parachute / ballast weights / onboard snacks etc) weight is then the lower of: a) Weight of the actual non-lifting parts subtract from the manuals max non-lifting parts weight of 230kg (507lbs). Or b) 115kg (253.4lbs) which the manuals max pilot weight. Or c) The max all up weight less the empty weight (very unlikely to come into play) This all assumes that the empty CofG limit is inside the manual limitations. The max weight without water is not relevant and most new aircraft don't list it. You know the max non-lifting parts weight (the critical point due to bending loads), and the max all up weight inc water (undercarriage/structural and flight stress loads), then the difference has to be all in the wings. The aircraft doesn't know if the wings weight is structure or water so is happy to fly! |
On Friday, October 19, 2018 at 8:00:05 AM UTC-4, Jonathan Walker wrote:
At 01:37 19 October 2018, Ouroboros wrote: That TN doesn't increase the max weight without water, which is the limiting number for this particular glider and the number that is not in the manual. Unless I am missing something all you need to know is the particular gliders actual (not assumed manufactured) weight of the non-lifting parts. The max pilot (actually payload, pilot / parachute / ballast weights / onboard snacks etc) weight is then the lower of: a) Weight of the actual non-lifting parts subtract from the manuals max non-lifting parts weight of 230kg (507lbs). Or b) 115kg (253.4lbs) which the manuals max pilot weight. Or c) The max all up weight less the empty weight (very unlikely to come into play) This all assumes that the empty CofG limit is inside the manual limitations. The max weight without water is not relevant and most new aircraft don't list it. You know the max non-lifting parts weight (the critical point due to bending loads), and the max all up weight inc water (undercarriage/structural and flight stress loads), then the difference has to be all in the wings. The aircraft doesn't know if the wings weight is structure or water so is happy to fly! This is a full description of where I was leading. Well stated. UH |
What about the weight of the horizontal stabilizer?Â* Given that it
produces negative lift and contributes to the bending loads on the main spar, is it considered a lifting part or part of the non lifting components? On 10/19/2018 5:52 AM, Jonathan Walker wrote: At 01:37 19 October 2018, Ouroboros wrote: That TN doesn't increase the max weight without water, which is the limiting number for this particular glider and the number that is not in the manual. Unless I am missing something all you need to know is the particular gliders actual (not assumed manufactured) weight of the non-lifting parts. The max pilot (actually payload, pilot / parachute / ballast weights / onboard snacks etc) weight is then the lower of: a) Weight of the actual non-lifting parts subtract from the manuals max non-lifting parts weight of 230kg (507lbs). Or b) 115kg (253.4lbs) which the manuals max pilot weight. Or c) The max all up weight less the empty weight (very unlikely to come into play) This all assumes that the empty CofG limit is inside the manual limitations. The max weight without water is not relevant and most new aircraft don't list it. You know the max non-lifting parts weight (the critical point due to bending loads), and the max all up weight inc water (undercarriage/structural and flight stress loads), then the difference has to be all in the wings. The aircraft doesn't know if the wings weight is structure or water so is happy to fly! -- Dan, 5J |
Jonathan: I agree that the max weight without water shouldn't be relevant, but I'm not the one that needs to be convinced. The last two people to do weight and balance for this glider both used the number from the TCDS.
805-609=196 lbs max pilot weight. How do I convince someone to ignore the number in the TCDS? |
Maximum aircraft weight a carrier catapult can launch? | J[_2_] | Naval Aviation | 6 | June 1st 11 10:01 AM |
Minimum amount of Maximum pilot weight | Nyal Williams[_2_] | Soaring | 1 | May 22nd 11 10:34 AM |
Fiberglass cloth weight vs 'finished' weight | Fred the Red Shirt | Home Built | 12 | April 5th 08 04:24 PM |
Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 09:26 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
