How does an aerotow rope break in two places?
Old October 23rd 18, 06:52 PM posted to rec.aviation.soaring
Steve Koerner
Default How does an aerotow rope break in two places?
It is a well known effect (hazard) that when a steel cable breaks under tension, it comes flying back, snaking all over the place. Now, steel stretches very little at failure, so this snaking is due to a transverse wave being induced. I suspect that the same thing can occur in a poly rope.
Tom
I think I can see why steel cable does what it does on breaking and why towrope wouldn't really behave the same. Upon breaking, the stretch of steel cable is released with a lot of acceleration and because of its momentum, it overshoots its neutral length. The cable has rigidity and buckles energetically when it recoils and pushes upon itself throughout its length. By contrast, poly rope has no need of buckling; it can go placid as it arrives at neutral length. Once placid, it won't support wave propagation in transverse or longitudinal mode. So, if there's any waves generated at the first breakage, those waves need to finish their work before the rope finishes unstretching.
Aerotow Regulations and Rope Specifications Markus Graeber Soaring 21 May 21st 15 04:30 AM
Actual Rope Break Kevin Christner Soaring 30 June 4th 14 04:59 PM
Rope Break! Waveguru Soaring 9 August 28th 12 03:17 AM
Rope Break Walt Connelly Soaring 4 April 12th 11 09:04 PM
Aerotow rope drogue chute? John Galloway Soaring 18 December 11th 03 05:37 AM
