Class mobility
Old December 6th 18, 05:31 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Class mobility
Of interest to me is that it looks like only one person (Geoff Brown) chose to "span down" and is flying with his shorter span tips. Everyone else is flying with the longest span their plane can fly with. No ASG29s, JS3s, Ventus 2C or similar in 15 meter class. And the other JS1 is flying with his 21 meter tips on.
Also of interest to me is that all classes are handicapped.
Steve Leonard
Old December 6th 18, 05:52 PM posted to rec.aviation.soaring
JS[_5_]
Steve Leonard
Most of the JS1s are B models, 18m only.
All the LS8s are flying with baby wingtips. One D2C flying at 18m.
I like the feel of the 18m D2C full of water, but at high speed it doesn't go like something with flaps.
Old December 6th 18, 06:20 PM posted to rec.aviation.soaring
krasw
Do these "phantom" classes give more FAI ranking points to pilots (4 winners instead of 2)? I dont see any other reason for this.
Old December 8th 18, 10:25 AM posted to rec.aviation.soaring
“Do these "phantom" classes give more FAI ranking points to pilots (4 winners instead of 2)? I dont see any other reason for this. “
No.
Old December 8th 18, 06:11 PM posted to rec.aviation.soaring
krasw
No.
Reading FAI ranking rules it sure does. Pilot quality factor, competition rating all are based on number of good pilots in same class. Put same pilots to multiple classes and you have very good phantom competition that gives a lot of ranking points. Very clever.
Old December 8th 18, 08:24 PM posted to rec.aviation.soaring
Tango Eight
No.
Where are the ranking rules to be found?
Who gets to decide if any given nation's rules are "close enough" to Annex A (or some other gold standard) to merit FAI rankings based on their nationals?
T8
Old December 9th 18, 05:58 AM posted to rec.aviation.soaring
krasw
lauantai 8. joulukuuta 2018 22.24.01 UTC+2 Tango Eight kirjoitti:
No.
T8
They are available online, you seriously want help in using google?
Old December 9th 18, 08:19 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
No.
T8
Hi Evan
Try this link http://rankingdata.fai.org/sc3d.pdf
Cheers
Colin
Old December 10th 18, 12:11 AM posted to rec.aviation.soaring
T8,
US Nationals have been used for FAI ranking over the years if the contest management decides to report the results and pays the associated sanction fees. This has been hit or miss over the years.
As an example you can see the FAI ranking for Phil Gaisford who has ranking based on the PanAms in 2015 that is a Category I event he won and then the 2018 US Standard Class Nationals which he also won and is considered a Category II event. As others have said, the ranking of each event changes with the “quality” of competitors.
http://rankingdata.fai.org/SGP_displ...p?pilotid=3167
Old December 6th 18, 06:42 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Steve Leonard
Yep, Jim, I was only speaking to the JS1c. One flying 18, one flying 21 meter. The one D2c also appears to be a turbo, so I am guessing he didn't want the really big wing loading hit if there were weak days. There are probably other Turbos that went "span up" for the same reason. And if you had an LS8 with 18 meter tips, I would think you would stick with the 15 meter ones because then you aren't going up against the flapped ships that are a generation or two newer than your plane. Yeah, they are racing against same span flapped wing ships in the "combined to make 15 meter" class, but their real competition is the Standard Class. They are more like me as "score sheet filler" in the 15 meter class. Yes, I see them in 3rd and 4th, but 800 points back.
Sure wish I was there, as it look like the weather has been good! May not see a thermal here in the flatlands of the US for another 2-3 months.
Steve Leonard
Airbus' Urban Air Mobility Roadmap leads to an electric future Larry Dighera Piloting 0 June 21st 17 04:50 PM
Airplane for mobility impaired passenger Sam940 Owning 1 December 10th 12 08:32 PM
Potential Club Class (US Sports Class) World Team Selection Policy Changes John Godfrey (QT)[_2_] Soaring 84 September 27th 10 08:03 PM
Lunar Roving Vehicle (LRV) Mobility Test Article (MTA) 0401759.jpg [email protected] Aviation Photos 0 April 10th 07 02:45 PM
Swidnik PW-6U Mobility and Fun Charles Yeates Soaring 0 March 6th 04 04:34 PM
