Rodent proofing CG Hook
Old February 28th 19, 06:55 PM posted to rec.aviation.soaring
Default Rodent proofing CG Hook
Keep in mind, dryer sheets and/or moth balls (did you spread its wing to sniff them?!?!.....dad joke....) are supposed to be a deterrent.
When they run out, or rodents can't smell, a mouse/Chipmunk/mole can fit through a dime sized hole, rats can get through about a quarter sized hole.
Keeping them away is good.
Keeping a food source away is also good.
Keeping them out if 1 & 2 fail........sorta problematic. There are quite a few small holes underneath most aircraft that rodents can get through.
Taken from someone that has dealt with this and has a major consultant in the pest control industry as family. I have asked these questions before on other applications.
Old March 1st 19, 01:30 AM posted to rec.aviation.soaring
George Haeh
Our local rodents are not deterred by moth balls.
Rodent leavings in the cockpit can be a small fraction of what's under the seat pan.
Compare/Contrast: CG hook on aerotow vs. CG hook on winch son_of_flubber Soaring 37 June 4th 12 10:40 PM
Rodent Deterrent, Part Deux rlovinggood Soaring 3 January 28th 08 02:41 PM
Rodent Deterrent? rlovinggood Soaring 20 January 7th 08 05:22 AM
Corrosion Proofing Clay Owning 7 April 22nd 05 12:03 AM
Corrosion Proofing Clay Restoration 0 April 18th 05 04:22 AM
