Interesting read in the link......longest span I have flown is ASK-21 and ASG-29.
Towing behind the car, yes... But in the air don't let it intimidate you.
To me the ASH25 handles just like an ASW20. Never spun one, but haven't tried in a 20 either. Will gladly accept the give-away ASH25 after the one Steve gets. Jim |
On Sun, 26 May 2019 07:53:58 -0700, JS wrote:
To me the ASH25 handles just like an ASW20. Never spun one, but haven't tried in a 20 either. I have and recovery is quite benign - recovery in 1/4 turn though 300 ft lower and doing 80 kts from a 45-50 kt thermal turn with zero flaps (position 3). I don't know whether this was specific to my early example (s/n 34), but it twice departed without warning from a 40 degree banked thermal term at around 45 kts with zero flap selected. I suspect in-thermal turbulence had a hand in that because the 2nd time it happened, I tried and failed to provoke a similar departure in late afternoon air after I finished the task. -- Martin | martin at Gregorie | gregorie dot org |
Martin,
Why are you thermalling in zero flaps? I always went to first positive flap position when thermalling the ASH-25 and never had a departure or even drop a wing. JJ |
On Sun, 26 May 2019 11:52:26 -0700, johnsinclair210 wrote:
Martin, Why are you thermalling in zero flaps? I always went to first positive flap position when thermalling the ASH-25 and never had a departure or even drop a wing. I did that primarily because I preferred the glider's feel in position 3. It always felt too stately in thermal flap (4) and didn't seem to climb that much better, except in very weak conditions. -- Martin | martin at Gregorie | gregorie dot org |
Dynamic Soaring Animation IEEE - ASH25 w/ Albatross Pilot | JohnDeRosa | Soaring | 17 | November 14th 13 03:59 PM |
"Airplanes don't kill people!, people kill people!" | Laonork | Owning | 8 | May 21st 12 05:56 AM |
Questions to ASH26E or ASH25 MI owners | Ludovic Launer[_2_] | Soaring | 3 | July 18th 08 08:20 PM |
"Airplanes don't kill people!, people kill people!" | Flyingmonk | Piloting | 11 | May 17th 05 10:26 AM |
ASW22 ASH25 or Nimbus 4 sharply needed for rent to Poland on EGC Pociunai | Lenti | Soaring | 0 | March 20th 04 08:59 AM |
