As I recall, there is a spring that keeps it in the locked position. Best to lock all 4 collars then pull forward on wing tips and re-tighten the forward sleeves, then pull aft on wing tips and re-tighten the aft sleeves. Check all springs inside collars.
JJ |
Replacing spherical bearings at the wing root? (Grob Astir CS) | Movses | Soaring | 9 | March 6th 15 09:39 PM |
Grob 109 wing pins | Bob Jenneson | Soaring | 6 | April 11th 09 10:45 PM |
Grob 109 wing pins | BT | Soaring | 0 | February 7th 09 05:05 AM |
"Costly Flaws Found In Navy's Top Jet: Wing mechanism wear could halve flight hours" | Mike[_7_] | Naval Aviation | 6 | May 18th 07 10:00 PM |
Grob wing retainer bearings | Tim | Soaring | 3 | September 3rd 06 02:55 PM |
