Grob G-103 Wing Pin Collar Found Disengaged
Old June 4th 19, 06:37 AM posted to rec.aviation.soaring
Default Grob G-103 Wing Pin Collar Found Disengaged
Part of every preflight. Or else.
Old June 5th 19, 11:37 PM posted to rec.aviation.soaring
George Haeh
Last winter Lindner issued us a new Flight Manual specifically for our serial.
After your helpful hints, I checked the new manual and found it now contains instructions to pull the wingtips back and forth while hand tightening the collars.
RTFNM
Replacing spherical bearings at the wing root? (Grob Astir CS) Movses Soaring 9 March 6th 15 09:39 PM
Grob 109 wing pins Bob Jenneson Soaring 6 April 11th 09 10:45 PM
Grob 109 wing pins BT Soaring 0 February 7th 09 05:05 AM
"Costly Flaws Found In Navy's Top Jet: Wing mechanism wear could halve flight hours" Mike[_7_] Naval Aviation 6 May 18th 07 10:00 PM
Grob wing retainer bearings Tim Soaring 3 September 3rd 06 02:55 PM
