Supplemental oxygen
Old July 24th 19, 02:31 AM posted to rec.aviation.soaring
Default Supplemental oxygen
I have been using, selling, installing and servicing oxygen systems for hang glider pilots and soaring pilots since 1991. My age is getting to be a factor, my field elevation is at 6,200 MSL (Moriarty, NM) with altitudes of 17,999 MSL on tap. I now set the MH EDS system to 5,000 and start huffing supplemental 02 about five minutes prior to launch. I have learned that it helps with my concentration on tow, especially during the turbulent and demanding midsummer conditions in the high desert. The amount of O2 used from 6,200 to release at around 8,000 and a climb to 10,000 is negligible.
Old July 24th 19, 02:52 AM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
I'm with Mark Mocho on this. As a midwest flat-lander I start O2 out west as soon as I am in the glider (one less thing to forget after tow). My aged red blood chemistry is just not up to handling the thin air at the 5,000+ft airports that I fly out of. My MH EDS is always set to D5 and sometimes late in a flight I change to R/M for 5-10 minutes as a pick me up.
Old July 25th 19, 04:59 AM posted to rec.aviation.soaring
Everyone needs to read the August 2018 issue of Soaring magazine issue on hypoxia by Dr. Dan Johnson, Jean-Marie Clement, Patrick McLaughlin, & Dr. Heini Schaffner - the idea that anyone would not understand the effects of hypoxia and the cumulative effects of high altitude flying without O2 is scary and incredible. There is ample information available to anyone as to the folly of ignoring lower O2 levels. It will open your eyes as to the need to start O2 at lower altitudes regardless of age. Hypoxia is not an on/off physiological event - the effects are cumulative. And what one person can "get away with" does not mean another person can, or the same person can the next flight - the effects are individual. Incipient hypoxia stars at relatively low altitudes, and impairment at higher altitudes and/or prolonged exposure can be catastrophic. Listen to the recording cited in the August Soaring magazine issue "XC Tips" article by Garret Willat (now posted on the SSA website). PEEP or pursed lip breathing, as John F. points out, is a "now" expedient technique that will temporarily increase O2 levels. If you have to use it, and don't have supplemental O2, you must descend NOW while you still have the ability to do so. The basic recommendation from the Soaring magazine article is to start O2 at 5kft, regardless of fitness level, etc. The o2 is cheap compared to the alternative. And for those who regularly fly at high altitudes (10 kft), of course you have a pulse oximeter along to periodically check your O2 saturation level.
Old July 25th 19, 05:29 AM posted to rec.aviation.soaring
Ramy[_2_]
I’ll confess. In the last 40 years I normally started my O2 above 12,500. I estimate I have something like 3-4000 hours between 5000-12500 without O2. I never felt a need to start any lower. I must be brain dead by now, which explains a lot
But seriously, each individual is different. Not everyone needs O2 at 5000 feet, or even at 10,000 feet, and it does not make them irresponsible idiots if they don’t stick a cannula in their nose every flight at every altitude.
If I ever crash please don’t blame it on hypoxia.
Just wanted to offer a different perspective.
Ramy
Old July 25th 19, 01:05 PM posted to rec.aviation.soaring
Pilots who live at higher altitudes (Colorado, New Mexico) definitely have an advantage, as they are well acclimated to the thinner air. I remember seeing visitors from low-lying states gasping as they tried to carry their hang gliders on 12,200 ft. Gold Hill at Telluride, while those of us that were more used to it were hauling 100+ lbs. up the last stretch to launch with no significant problem. Of course, we were a lot younger then....
Old July 25th 19, 08:29 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Ramy wrote on 7/24/2019 9:29 PM:
....and that's why pilots should check their saturation with an oximeter even lower
than they would normally start using oxygen. People's responses do vary a lot.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old July 25th 19, 09:36 PM posted to rec.aviation.soaring
Dan Marotta
I've got an oximeter in the Stemme but never used it in flight. I'll try
to remember to do that just to see the results.Â* I currently set my MH
regulator to 10K' but, given that I have my own O2 fill capability, it
wouldn't hurt much to lower that to 5K' just to see if I notice any
difference.
Oh, and I've attended USAF altitude chamber training twice while I was
in the AF and am familiar with my hypoxia symptoms.Â* I wonder if they
change with age...Â* And I've experienced a cabin pressure failure at
FL450.Â* Pressure breathing is not much fun!
oximeter even lower than they would normally start using oxygen.
Dan, 5J
Old July 26th 19, 04:31 AM posted to rec.aviation.soaring
jfitch
If I have to turn on the oxygen at 5K, I'm going to have to do it in the truck on the way up the hill to the airport. And keep it on the whole time I'm there. Airport is 6K and our takeoff is typically at 9000 ft density and can be 10K. 5K may make sense if you are a retiree living at 20 ft in Florida, but it lacks both practicality and necessity for everyone in every situation.
Old July 26th 19, 05:39 AM posted to rec.aviation.soaring
I will say it again - read the article in Soaring magazine - then comment. Opinions and anecdotes are fine, but I think we would rather bet our lives on actual data. The FAA "guidelines" were set circa WW II and were not based on physiological realities. The article explains the onset of hypoxia, and contains test results on a variety of individuals showing that the FAA regs are severely out of date as to onset altitude. Incipient hypoxia occurs at low altitudes (5-8kft), regardless of age and conditioning. Incipient does not mean disabling, but it is the start of (probably unnoticed by the individual) degradation of performance. The article does not address the question of whether individuals living at high altitudes (my house is at 6400 ft, but I turn on the O2 before taking off from Moriarty at 6200 ft) experience the onset of incipient hypoxia at higher altitudes. The article recommendation is on the side of ensuring sufficient O2 from start to finish of flight by those who have run and documented test results.
Old July 26th 19, 06:40 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
jfitch wrote on 7/25/2019 8:31 PM:
Don't worry about the density altitude, as your lungs respond to actual pressure,
unlike a carburetor.
Oudie Supplemental Power Pack Roy B. Soaring 24 September 30th 17 06:46 PM
Oxygen Jim[_18_] Soaring 5 September 28th 11 11:59 PM
News flash: pilots are "allowed" to use supplemental oxygen VARR Soaring 8 August 17th 08 04:54 PM
SZD-55 and oxygen David Pye[_2_] Soaring 0 February 27th 07 08:04 AM
Supplemental O2 and children Peter R. Piloting 23 April 18th 06 01:47 PM
