Lift pins
Old July 26th 19, 11:39 PM posted to rec.aviation.soaring
Default Lift pins
On Friday, July 26, 2019 at 5:50:02 PM UTC-4, wrote:
Dirk,
Those are not,”poor little root ribs”, in fact the designers have reinforced them with several layers of cloth running from the spars deep into the root ribs on both sides of the spar, so that they will transfer the fuselage load into the wings.
JJ
Wing skins also play a meaningful part in handling the loads.
UH
Tapered pins (again) [email protected] Soaring 22 April 28th 18 03:06 AM
Grob 109 wing pins Bob Jenneson Soaring 6 April 11th 09 10:45 PM
ASW-15B spar pins [email protected] Soaring 1 May 9th 06 12:46 AM
Shear Pins for Propellors? Rich Lemert Piloting 25 April 3rd 05 09:04 PM
taper pins Ernest Christley Home Built 4 September 12th 03 03:15 AM
