source for clips or sleaves for Hotelier linkages
Old July 29th 19, 09:09 AM posted to rec.aviation.soaring
James Thomson[_2_]
Default source for clips or sleaves for Hotelier linkages
At 07:57 29 July 2019, John Foster wrote:
On Monday, July 29, 2019 at 1:17:38 AM UTC-6, John Foster wrote:
On Sunday, July 28, 2019 at 6:09:07 PM UTC-6, Steve Bralla wrote:
On Monday, June 15, 1998 at 12:00:00 AM UTC-7, Al wrote:
Anyone got any good suggestions for clips for hotelier linkages.
I also understand that there is a sleave kit out there somewhere.
=20
Thanks
=20
Al
Sleeves? I can't help. Pins? Aircraft Spruce
https://www.aircraftspruce.com/catal...owlingpins.php
=20
Thanks for all the links, guys, but these are not the spec that is
called=
for in this AD. The glider in question is a Bolkow Phoebus, but I
believe=
this AD also applies to the Standard Cirrus, as well as some others
(corre=
ct me if I'm wrong). It specifically states the clip must be 1.2mm
diamete=
r wire, and gives a picture of the clip going across the push rod. In
this=
particular application, the push rod is only about 1/2" diameter, so a
cli=
p that is 1.5" long will stick out the sides too far and hang up on the
sur=
rounding structures. Here's a link to the AD:
=20
http://www.ltb-lindner.com/phoebus-ad-sb.html
=20
Look particularly at the PDF link "13 94_001 L`Hotellier
Verschluesse.pdf=
(94,4 kB)". =20
=20
It gives pictures and dimensions of the clip needed. It specifically
men=
tions a specific L'Hotellier part #140-31, or equivalent Ford part
number
1=
473 931, but neither of these part numbers come up with anything
other
than=
copies of the AD when a Google search is done. I can not find a
source
fo=
r these specific parts.
More specifically, these connections are for aileron and spoiler push
rods
that come through holes in the wing root rib. If the clips stick out too
f=
ar, they will snag on the edges of the holes in the wing root rib and
cause=
the control surfaces to hang up and not move properly. Obviously,
that
wo=
uld be very bad.
I think that you are getting the various locking devices confused! The
AD is issued by LBA - Google LBA 193-001/3 for the current version.
There are various locking methods to choose from - safety pins, Uerling
sleeves, LS locking sleeves, Schempp-Hirth clips, Wedekind sleeves are
all mentioned in the AD.
The L'Hotellier and Ford safety pins are very small and simply go through
the connector lock plate as shown on the second page of the Lindner
document. They do not go round the push rods or stick out to foul the
holes in the root rib.
Old July 29th 19, 09:39 AM posted to rec.aviation.soaring
John Foster
=20
Thanks
=20
Al
=20
called=
believe=
(corre=
diamete=
this=
cli=
sur=
=20
=20
Verschluesse.pdf=
(94,4 kB)". =20
=20
men=
number
1=
other
than=
source
fo=
rods
f=
cause=
that
wo=
uld be very bad.
Exactly. These are the type of connectors on my glider, and I am looking for a source for these "very small" pins. I realize there are other newer and better connectors, and one of those options may be in my future. But for now, I need to drill holes as mandated by this AD and use these specific small pins. Where can I find them?
Old July 29th 19, 09:47 AM posted to rec.aviation.soaring
Look at a RC car supplier (like, Tower Hobbies) for "body pins" used to hold a RC car body onto the chassis.
IIRC, we used to use dental floss tied onto the pin and pushrod so you didn't lose the pin.
Old July 29th 19, 10:10 AM posted to rec.aviation.soaring
John Foster
On Monday, July 29, 2019 at 2:47:32 AM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
Thanks. Is this acceptable for a standard airworthiness certificated glider?
Old July 29th 19, 04:33 PM posted to rec.aviation.soaring
Dan Marotta
Why not?
My Stemme has so many non-aircraft parts as delivered from the factory
that you wouldn't believe it.Â* Did you get your vario from and have it
installed by a certificated avionics shop?Â* Is that an aircraft battery
that's powering your avionics?Â* We're talking about bobby pins here.
Dan, 5J
Old July 29th 19, 10:08 AM posted to rec.aviation.soaring
James Thomson[_2_]
Google "R clips" ( guess why they are called that...!) Totally agree
about a
light safety thread to avoid losing the clip into the bottom of the
fuselage.
Old July 29th 19, 04:28 PM posted to rec.aviation.soaring
Dan Marotta
THESE
https://www.walmart.com/ip/Unique-Bargains-50pcs-R-Split-Mechanical-Hitch-Hair-Tractor-Cotter-Clip-Pin-1-6mm-x-28mm/546161908
are what I use.Â* Never run out again.
If those seem too cheap, send me $139.95, and I'll send you 6 of them. :-D
=20
Thanks
=20
Al
=20
called=
believe=
(corre=
diamete=
this=
cli=
sur=
=20
=20
Verschluesse.pdf=
(94,4 kB)". =20
=20
men=
number
1=
other
than=
source
fo=
rods
f=
cause=
that
wo=
uld be very bad.
Dan, 5J
Old July 29th 19, 04:40 PM posted to rec.aviation.soaring
George Haeh
What T8 did not mention is that the part of the pin that goes through the rod is bent to keep it permanently on the rod.
Very hard to drop into inaccessible cavities once installed.
Look at both of T8's photos to see how it's done.
Old July 29th 19, 04:58 PM posted to rec.aviation.soaring
John Foster
I wish we could post photos on here like a "normal" forum. None of these solutions offered will work, because the clips are too long and will bind on the wing root rib as the ball joint moves back and forth through it. It is indeed the rotating cam variety of straight L'Hotellier ball connectors, as Scott Williams surmised. The smallest "R-clip" I've been able to find on Amazon is now 22mm long. This still would be too long, I would think. The holes in the wing root rib where the push rods exit are quite small, and the push rods are not centered in the holes either.
Old July 29th 19, 06:31 PM posted to rec.aviation.soaring
Scott Williams
Hey John,
62 FR 17537 - Airworthiness Directives; Louis L'Hotellier, S.A., Ball and Swivel Joint Quick Connectors
lindners online website lists the original A.D. in Europe. specifies clips only.
However, The U.S. FAA , allows safety wire. I fly with a club member who has a Phoebus A, and I owned a Phoebus C, Neither one of us was ever able to find any clips short enough to not rub on the tubes. properly located holes drilled into the cams and safety wire were the only solution we found.
It's A PITA, but once you've done it a few times not such a big deal.
Don't forget the required placard.
Good Luck,
Scott
source for clips or sleaves for Hotelier linkages John Foster Soaring 41 August 22nd 19 01:48 AM
Source for L'Hotellier Safety Clips George Haeh Soaring 23 January 29th 19 12:20 AM
L'Hotelier Fitting Safety Pins Dan Marotta Soaring 20 October 17th 16 01:40 AM
Hotelier safety sleeves [email protected] Soaring 6 August 31st 07 03:41 PM
Lycoming throttle linkages Evan Carew Home Built 0 September 29th 04 01:58 AM
