fes ot jet (pros and cons)
Old August 9th 19, 07:04 AM posted to rec.aviation.soaring
Default fes ot jet (pros and cons)
The manufacturing tolerances issue in M+D jets was what was related to surging after the start in South African conditions and before they reached the certification stage IIRC. My early pre- certification jet didn't have that problem. Over 135 starts during my time of ownership (mostly ground and air tests in both Scotland and South Africa) what I did find was that it didn't start reliably in cold UK conditions with diesel fuel but was fine with jet A1, whereas in SA it was very unreliable on jet A1. At the suggestion of the factory I started using premium synthetic/petrochemical diesel fuel (Shell V-Power Nitro) and with that it started 100% in both cold UK and hot/high SA. That stuff contains no biofuel btw.
The other thing I learned myself was to use an additive such as Biobor to prevent microbial overgrowth from clogging the fuel filters. 1 ml added to 10 litres was all that was required.
Old August 9th 19, 02:04 PM
RickH RickH is offline
Junior Member
First recorded activity by AviationBanter: Feb 2016
I have a JS-1C TJ as well. I had no issues with starts but rolling the throttle up through 45% produced a Flame Out. Turned out to be tolerance issues and was addressed by M&D very satisfactorily. They turned it around quickly and I haven’t had an issue since. Engine test in the start cylinder for every flight, and the occasional beat-up upon request, and not a failure since its return. I’ve used Jet-A and Diesel with good results but rely on Diesel due to availability around contest sites and M&D’s recommendation. 60-seconds to full power and the equivalent drag of your gear make it pretty attractive. 250-km saw-tooth range is a bonus as well. But yes, there is an airport, or good field within range on every start.
Rick
NR
Old August 9th 19, 07:40 PM posted to rec.aviation.soaring
Jet - we have heard opinions on reliability.
How many cases of Fes not performing?
Any experiences, anyone?
S
Buying a 1-35 pros and cons? [email protected] Soaring 42 May 29th 20 05:38 PM
Pros and Cons of a 501(c)(3) Operation Randy Teel Soaring 4 March 7th 12 03:39 PM
Starduster One pros and cons [email protected] Home Built 11 November 2nd 06 07:37 PM
Starduster One pros and cons [email protected] Piloting 2 October 29th 06 06:40 PM
AUTOPILOT PROS & CONS STICKMONKE Instrument Flight Rules 53 May 23rd 06 11:16 PM
