simple enough to make using a db15 connector. You should check the manual for your particular serial number radio to be sure nothing has changed but for mine the pinouts are as follows:
+12v - pins 4, 5 Ground - pin 2 PTT switch - pin 12 PTT ground - pin 3 Audio Ground - pin 9 Audio signal - pin 15 Mic in - pin 11 Mic ground - pin 10 All ground lines (2, 3, 9, 10) are tied together internal to the radio. All +12v lines (4, 5) are also tied together internal to the radio. Robert On Wednesday, September 4, 2019 at 3:36:42 PM UTC-5, Bob Youngblood wrote: I have a radio that needs a wiring harness, Becker AR3201 can anyone help. Thanks, Bob |
looking for Hooker harness | Al MacDonald | Home Built | 0 | July 12th 08 03:54 PM |
engine monitor wiring harness install | Jim Burns | Owning | 8 | November 20th 06 02:26 PM |
S-H safety harness (V2C) | [email protected] | Soaring | 20 | April 28th 06 08:54 AM |
Harness | Nolaminar | Restoration | 2 | December 25th 03 03:04 PM |
Narco AT-50A Wiring Diagram Needed | Jerry | Aviation Marketplace | 0 | August 3rd 03 11:07 PM |
