Wiring Harness Needed
Old September 6th 19, 10:58 PM posted to rec.aviation.soaring
JS[_5_]
Default Wiring Harness Needed
On Friday, September 6, 2019 at 8:16:50 AM UTC-7, wrote:
I’ve purchased three harnesses over the last few years. One made by Goddard was by far the nicest unless you try and get an original factory replacement.
The factory replacement harnesses for these older radios aren’t readily available, so you might end up with a newer model radio harness and have to
dead end a number of wires in the harness for functions the older radio doesn’t have.
The Goddard harness I purchased was well made, Tefvel wiring, each wire and function labeled, appropriate ends on the wiring for shielding, etc. it’s the only way to go as far as I’m concerned, especially with an older but quite functional radio!
And I’m sure any of the soaring supply distributors would appreciate it as well.
Regards, Mark
For 90% of pilots, that's the way to go: Buy a harness for the new radio.
And for those thinking about upgrades, the stuff from 30 years ago may not be compatible with new models but some intermediate models may have the same wiring.
I've recently replaced a FSG-71M with an FSG-2T... Plug and Play.
Also replaced an AR4201 with an AR6201... Plug and Play.
Removed another FSG-2T, replaced with XCOM, a bit of work and a microphone change.
Later replaced the XCOM with a TY91. Ordered a harness with the TY91.
Consider the compatibility of microphones in the upgrade. Some radios do not have inputs or preamps for different microphone types. One reason for changes to the wiring harness of newer radios.
The newer ones may have auxiliary audio inputs. Some have separate microphone and PTT connections for each seat. More attention may have been paid to grounding schemes.
There are different pin counts and locking types for D-Sub connectors.
Pretty much replacing anything that doesn't fit in a 57mm cutout is going to take some work. But it'll be worth it!
looking for Hooker harness Al MacDonald Home Built 0 July 12th 08 03:54 PM
engine monitor wiring harness install Jim Burns Owning 8 November 20th 06 02:26 PM
S-H safety harness (V2C) [email protected] Soaring 20 April 28th 06 08:54 AM
Harness Nolaminar Restoration 2 December 25th 03 03:04 PM
Narco AT-50A Wiring Diagram Needed Jerry Aviation Marketplace 0 August 3rd 03 11:07 PM
